anyone getting the grom vline?
Old 10-09-18, 08:29 AM
  #1396
Arvid
Arvid's Avatar
So VL2 users, And GROM .....
are the VLine so good now , that it's time to ask Grom to send me VL2 upgrade stuff needed for a VL1 that has been tucked away in the closet for a more than a year now, waiting to get it updated with this option and finally have Vline to work as it should when it first was launched...? 😉
Regards
Arvid in Norway
2008 LS600hL w/ML
Old 10-09-18, 08:35 AM
  #1397
rehr0001
rehr0001's Avatar
Originally Posted by MikeB139
So are most problems solved now?
No more random crashes (mainly using Carplay)?
If I start my car, would it work instantly or does it require to boot up?
Oh and what about the reverse camera, does that work and does it go back to the vline once you put it back in anything other than reverse?
Most problems are solved now. Random crashes will always occur. They are infrequent.
It isn't instant - takes about 20 seconds to boot. By the time I start my car, situate myself, plug in my phone and back out of my driveway, it's ready to go.
Reverse camera has never been an issue for me (07 LS460) it seems like the issues are model/year specific.
Old 10-09-18, 10:47 AM
  #1398
baviaannl
baviaannl's Avatar
are the VLine so good now , that it's time to ask Grom to send me VL2 upgrade stuff needed for a VL1 that has been tucked away in the closet for a more than a year now, waiting to get it updated with this option and finally have Vline to work as it should when it first was launched...? ��
Regards
Arvid in Norway
2008 LS600hL w/ML
I read these reports from users and think "you guys must be using a different system altogether!" I've had the V2 installed since mid August and haven't suffered a single problem. I think on 2 occasions I've started the car and the Vline boot screen hasn't appeared, I simply pushed the disk button and it was back again.
Carplay has never crashed for me either.
I think its an excellent and reliable piece of kit. Who knows why the other guys are having so many issues!
Old 10-09-18, 12:04 PM
  #1399
newgsman
newgsman's Avatar
My VL1 goes to vertical lines screen quite regularly. So disappointing. Not hearing much from VL1 users on this thread lately. Am I the only one that still has issues or is still hoping it will magically become problem free?
Old 10-09-18, 12:07 PM
  #1400
baviaannl
baviaannl's Avatar
I think the V2 ironed out all the issues the V1 presented. I get the impression the V1 isn't really supported any more.
Old 10-09-18, 12:52 PM
  #1401
gromaudio
Vendor
gromaudio's Avatar
It should not do that. Make sure to update your unit to the latest versions.
Please connect to the Wifi network with internet access.
Then click on Settings->About Device->VLine System Updates->Check For Updates
Old 10-09-18, 01:36 PM
  #1402
newgsman
newgsman's Avatar
Last time I checked for updates, I accepted the prompt to update to newer versions. After I did that the system went dead. Your response to that condition was the following:
We see occasional update process glitches in some cases. It is not related to firmware but update sequence itself. We still work on it and it will help if you contact our support and pass all information that you have. In any case, here is the emergency recovery page:
https://gromaudio.com/software-vl1.html
__________________
So I updated using the recovery page and the unit started working again except now I routinely get vertical lines pretty much everyday.
Apparently when I check for system updates it says updates are available but of course I don't want to accept for fear my unit will go dead again.
My unit has Vcore: VL3.3.9.0 Vbase: 31.22(L20)
Old 10-10-18, 04:32 AM
  #1403
baviaannl
baviaannl's Avatar
@gromaudio May I ask how the Android 7.1 beta test is going?
Old 10-11-18, 09:50 AM
  #1404
gromaudio
Vendor
gromaudio's Avatar
We will release first 8.1 beta for testing next week. Will see from there if any issues reported.
Old 10-12-18, 01:33 PM
  #1405
newgsman
newgsman's Avatar
Well I took a chance a updated the latest versions.
Now I keep getting a message that Dashlinq has stopped working. The Local Music Player app now sees my USB stick with my music just long enough to load up all the songs and folders and then it crashes and stops being able to see the USB stick. If I check Vline storage the Settings app it shows that Vline still recognises that the USB stick is there.
So if I use the older version of software I can listen to my music but the screen will keep crashing to vertical lines mode. Or I can use the new software version and just not listen to music. Interesting fixes ...
Old 10-12-18, 01:36 PM
  #1406
baviaannl
baviaannl's Avatar
I really wish @gromaudio would release a changelog, for example I had a new update available yesterday so I upgraded, a clue of what it added would be good.
Old 10-12-18, 01:47 PM
  #1407
gromaudio
Vendor
gromaudio's Avatar
Please do the factory reset. Android Settings->Backup and Recovery->Factory Reset.
Old 10-12-18, 02:23 PM
  #1408
newgsman
newgsman's Avatar
If I do a factory reset will I have to reinstall all my apps that I downloaded like maps.me, and googlemaps?
Old 10-12-18, 04:33 PM
  #1409
gromaudio
Vendor
gromaudio's Avatar
Yes you will. Try go to Android Settings-> Apps -> All -> Dashlinq ->Clear Data
Old 10-17-18, 01:01 AM
  #1410
baviaannl
baviaannl's Avatar
I downloaded the newest firmware (available in the UK) a few days back, unfortunately this has added both Bluetooth and WiFi instability. Sometimes when I start the car, neither will connect. If I turn the car off and restart 30 mins later, this normally fixes the issue. I've had it twice in 4 days. Prior to that update, I've never experienced this issue before.
Quick Reply: anyone getting the grom vline?
