anyone getting the grom vline?
#1441
https://m.apkpure.com/car-launcher-a...es.carlauncher
Comes for both Io and Android
Have it on mobile like this:
Still not heard from Grom about the update parts needed to upgrade to v.2..My v.1 replacement will not be installed in my car before it's 100% stabile. Lost enough hair and sleep stressing around in the garage for hours to get the 1st one they sent me to work more than a litte while at a time before it died all together ...what did Grom do, shipoed it back to mr with new cables...did it work..NO ..Shipped it for the second time back to Grom and got a new one that time..That last one I have not installed at all and have waited more than a year for the upgrade the V.1 to V.2 parts they promised me to be available..
Just checked my mailbox...86...Yes ...eightysix differrent conversations made with Grom since May 16- 2016...and still NoGo..
Arvid
Arvid
#1442
Yes, I use Car Launcher AGAMA on my V1 and much prefer it over whatever grom comes with stock (DashLINQ I think?). You can find my prior posts about it in this thread. It seems to load faster and run smoother. It definitely looks better and has better functionality IMO. Would definitely recommend it.
Wandering if you have used both for any comparison comments.
Im always on the lookout for some nice apps to run on the Vline. Any other suggestions?
#1444
That car launcher looks pretty good. Have you used Carwebguru launcher. Im using that and it appears similar but i cant get the speedometer widget to work.
Not really. I'm a fairly basic user. I'd recommend keeping as few apps loaded as you actually need to keep the unit as fast as possible though.
#1445
I have not used that launcher. I might check it out though... AGAMA hasn't been updated in awhile and they removed the speedometer widget on the homescreen with one of the last big updates (though it wasnt super responsive anyways...) so I'm open to new options.
I use spotify with waze as its integrated now with the widget overlapping which is cool.
Beyond that i have minimal apps too to keep it quick. I like the dashlinks web radio but as its a plugin not app, i cant get it to work with aftermarket launchers unless i make my homescreen Dashlink. Beyond that just use Youtube etc
#1446
Speed screen
WillAP1
The speedometer vidget (and a few other options) will appear if You touch the centre of the app..where I have my Lexus logo
Arvid
Arvid
#1447
WillAP1
The speedometer vidget (and a few other options) will appear if You touch the cent of the app..where I have my Lexus logo
Arvid
Arvid
#1448
#1449
CarPlay works perfectly with AGAMA, just plug your Iphone in and the interface loads immediately.
#1450
I’m talking about after the phone is connected and I bounce out of CarPlay (using the Grom icon) and want to return. Occasionally I want to access a native Android app outside of CarPlay. Currently cycling the phone connection, or closing out of AGAMA is the only way to do that. From what I can tell the plugins are exclusive to Grom’s Dashlinq. It would be nice if the VLine features were implemented so that all launchers could utilize them. I suspect this is an issue Grom would need to correct and not AGAMA, but I’m really not sure.
#1452
Was hoping someone could advise regarding hotspot. I currently use an app called Macrodroid. Works flawlessly.
I get into the car, start it up and through some macros i created, it automatically connects to the Vline via hotspot (hotspot on, wifi off, bluetooth connected to the car etc). Same when i exit the car (macro kicks in = hotspot off, wifi on, bluetooth remains on etc).
My issue is when i receive or make a call. This automatically turns off my hotspot and when i finish the call i have to manually turn the hotspot back on or no connection to Vline. I havent figured out a macro that works yet to re-enable hotspot after a call.
Has anyone had any luck with this or can share alternative solutions, thanks.
#1455
Final 8.1 testing scores and overall long term stability. Shooting for next week with the alpha version !
