RC-F Differential into IS-F?
Old 05-25-22, 04:17 AM
  #136
BertoISF
BertoISF's Avatar
Where is this code? Is it the one on the VIN sticker inside the driver's side door?
ooof that was rough. I thought the decoder was for the sticker on the diff. Now i see even the URL had VIN in it. 🤫
Old 05-25-22, 08:55 AM
  #137
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,018 Likes on 2,434 Posts
I did a search for RC F VIN and looked at the images. Lots of A01A, and some A01B for these models. After poking around a little, there is a lot of conflicting information about decoding these codes. One thing is pretty consistent - the A at the end is an open diff. Odds are pretty good the B at the end is a Torsen diff, but it would need to be confirmed with an owner to be sure.
Old 05-25-22, 01:14 PM
  #138
flowrider
flowrider's Avatar
Received 1,928 Likes on 1,360 Posts
^^^^Are you sure I don't think any RCFs were shipped with an open diff. It would seem to me that the "A" is a Torsen and the "B" a TVD.
Old 05-25-22, 01:49 PM
  #139
JT2MA71
JT2MA71's Avatar
Received 1,576 Likes on 688 Posts
Technically, the TVD equipped RC F’s have open diffs. But I don’t know if Lexus would name it way. I’ll check what mine says when I get home today.
Old 06-03-22, 11:33 AM
  #140
WhyHateTho
WhyHateTho's Avatar
Will the LC 500 differential fit the ISF?
Old 06-07-22, 04:01 PM
  #141
BertoISF
BertoISF's Avatar
Any words of wisdom for lubricating the axle seals before putting the axles in? Any lubricants to avoid? Trying to avoid any hard lessons (like using the wrong lube deteriorates the axle seal).
The ones that were on the donor diff looked like it had dielectric grease on it.
Old 06-07-22, 10:14 PM
  #142
lobuxracer
Tech Info Resource
lobuxracer's Avatar
I use Red Line Assembly lube for anything like this. It dissolves quickly once oil hits it and works very well on seals. It's even better in rod and main bearings.
Old 06-18-22, 07:20 PM
  #143
BertoISF
BertoISF's Avatar
Another RCF transplant complete. This thing rips now!
btw i'd had my air hammer sitting in my tool chest as part of an air kit that came in with my air compressor...20 yrs ago. I never realized how sweet this thing is (for bushings).
The following 3 users liked this post by BertoISF:
JT2MA71 (06-21-22), mikellucci (06-19-22), MileHIFcar (06-19-22)
Old 06-20-22, 09:25 AM
  #144
superspeed
superspeed's Avatar
Has anyone looked into swapping the 2020+ RCF Diff with the revised final drive?
autovation (12-27-22)
Old 06-20-22, 04:52 PM
  #145
MileHIFcar
MileHIFcar's Avatar
That would be interesting to know?!👆
What is the final revised drive ratio of the 2020+ RCF's?
Old 06-20-22, 05:33 PM
  #146
superspeed
superspeed's Avatar
3.13 final drive
Old 06-20-22, 05:36 PM
  #147
JT2MA71
JT2MA71's Avatar
3.13. I bought a used open diff off of a 2015 rc350, same gear ratio, had the ring and pinion Cryoheat treated and built one with new housing and OS giken LSD. Car scoots more aggressively and rpm at highway cruising isn’t too much higher.
The following 2 users liked this post by JT2MA71:
MileHIFcar (06-21-22), minator (11-22-22)
Old 06-22-22, 07:13 AM
  #148
JDMV8
JDMV8's Avatar
I thought about doing exactly this, sans the cryo treatment, but with 3.266 (GS450h) or 3.615 (GS350) and oem ISF housing + OSG LSD. 3.13 is surely an upgrade, and I think 3.615 might affect drivability of the car poorly. Probably aiming for 3.266.
JT2MA71 (06-22-22)
Old 06-22-22, 07:28 AM
  #149
JT2MA71
JT2MA71's Avatar
I have initially wanted the 3.2 and decided to try the 3.13 first to see how I like it. I think I will stay with it for a while. The acceleration improvement is there, but obviously the 3.2 would be even better. But, I still do quite a bit of freeway driving and I think 2K rpm at 70 mph in 8th gear is perfect, for me at least.
Old 06-22-22, 08:52 AM
  #150
JDMV8
JDMV8's Avatar
2k is great. 3.266 should increase that by 5%, so 2100rpm seems fine too. Way better than my 5speed evo...4k rpm at 80mph, stock gearing, and I highway that car more than the Lexus.
The following 2 users liked this post by JDMV8:
JT2MA71 (06-22-22), minator (11-22-22)
Quick Reply: RC-F Differential into IS-F?
