RC-F Differential into IS-F?
#151
For the DIY's who struggle getting the axles out of this diff, this worked great for the 350. HF bearing puller and 1/2" All-thread. No we have something to pry on. Get two bars up there and give it a good pop.
With one axle out, a long drift was used to pop the other out. It fits past the spider gear shaft, and with one hit, the axle is out.
And yes, air-hammer is good for those rear bushings too as well as a BFH and prybar. A drill was used to split the shell on the front bushings and those pop out pretty easy taking 5min or so to split the shell.
Used diff going back in while I wait for tools.
That wood stand made of 2"x6" and 2"x4" was a game changer putting it back in solo. Loosening the carrier bearing up in the tunnel also gives you some wiggle room to fit the driveshaft back onto the pinion flange.
Minor bushing carnage. PS - the single hole unit is oil filled. Careful what you do to it. Those were 10min each. Not bad.
Anyone know of a good tool for those 100mm clips holding side bearings in the case? Please let me know! Thanks!
Build thread is here. Pick up at post #352 for delayed OS-Giken install.
The following 2 users liked this post by 2013FSport:
RJMacReady (09-13-24),
steeven001 (07-12-22)
#152
Lang Tools 87 Heavy Duty Pliers with Tip Kit https://a.co/d/1uCwpDO
2013FSport (07-11-22)
#153
Tech Info Resource
My dad welded two roller bearings onto a pair of large Vise-Grips. Stupid easy with that thing, but you need the welder and roller bearings the right size laying around.
The following 2 users liked this post by lobuxracer:
2013FSport (07-11-22),
JT2MA71 (07-12-22)
#154
This what I used, worked well on all 3 diff builds I did so far.
Excellent! I saw those ans they went to the "most likely order these list" but didn't know if the tips could handle the pressure.
The holes are 5.5mm (0.22") or so. Good to know they work as intended for this application.
So, you installed the OS -Giken in a couple of cases? Did the cases need grinding or what method was used to get it in there if it didn't drop in freely??
TIA
#155
TIA
TIA
#156
Do your drilling towards the diff not away from incase you get into the cast iron.
If you miss, keep going up in drill sizes and eventually you will wear through them.
I did one in 5min and one in 20min when I missed and had to move up drill sizes.
Split the shell and they fall out.
#157
Tech Info Resource
Mine air chiseled out in less than a minute each. Crush to the middle, see them drop out.
#159
I ordered that tool and it should arrive today. We'll see if the housing accepts the OS-G. Best guess is no on the open diff.
Have you done anything with the pinion bearings on these or just left them alone.
Thanks!
#160
Tech Info Resource
Didn't change anything on mine. If you change the bearings, you may find it necessary to order new snap rings to move the tooth engagement. Mine did not need that as the tooth engagement was right where it should be.
2013FSport (07-14-22)
#161
The first OS Giken build I did, I replaced only the side bearings, gear engagement and backlash did not change. The second build, also new bearings and OS unit, did not need new snap rings, didn’t touch the pinion on both builds. 3rd build, is the 2nd diff which I decided to get a new finned case and have the ring and pinion (3.13) Cryoheat treated and micro polished. Since this is now using a brand new case, I had to dial in the gear engagement and backlash, pinion height also was also set.
#162
It is getting new OEM bearings on the carrier. The total rotational torque was just barely in spec. and the unit consistently maintained 100°F temp when checked which to me indicates pretty minimal preload on the bearings.
We shall see.
#163
I have to say that getting that first snap ring out was a pain and these bearings have minimal preload on them. I'm hoping I don't need a case spreader or some means of compressing the races to get the thing back together.
We shall see.
We shall see.
2013FSport (11-29-22)
#164
Tech Info Resource
We shall see.
We shall see.
