RC-F Differential into IS-F?
#166
Tech Info Resource
@JT2MA71 @lobuxracer
A quick question, did you guys replace the 10X ring gear bolts or just reuse? Any DIY tricks for holding it during the final torque steps?
TIA
TIA
#168
TIA
TIA
2013FSport (08-06-22)
#169
Always replace those bolts, they are "torque to yield" bolts. You'll need a proper fixture, maybe a bench vise. Torquing to the initial spec is easy, turning to 60-90 degrees is what's tough to do. I made a mark on each bolt after they were all torqued to the initial torque, I forgot, is it 43 ft/lb? and then used impact wrench to turn them to full yield. Put red loctite on the threads and under the head flange, it will keep the bolt heads from binding and will be easy to turn to 60-90 degrees with an impact wrench.
The open diff was easy to hold with 2X 2x4" in a vice, this has no flat spots making a need for spanner off the bolt heads or something like that? But an impact will make it easier for certain. Although it does unsettle me slightly. Copy that I'll get some new bolts on order.
I couldn't find a cross-reference for the loctite, I have blue 242 rated to 300 deg, but I'm not sure of its long term fluid resilience?
Did you freeze the spool or heat the ring gear? If freezing, is that enough compared to heating the gear to 212°F ? The gear came off pretty easy so there is that.
Ring gear bolts are 47ft/lbs.
#172
Tech Info Resource
I didn't do any of this. I reused the front bolts, installed the bolts that came with the poly rear bushings, and didn't loctite anything. Everything got torqued to spec. Been running this way for more than 50k miles and only had a problem because I didn't get the 90 durometer rear mounts the first time. None of these are torque to yield except the ring gear bolts. I did replace those, but there's an easy way to check those kinds of bolts. Measure a new one. Measure a used one. If the used one is longer than the new one, it's toast. Same thing with rod bolts - measure unloaded, and measure with full torque. They should be stretched at full torque and the actual length under load tells you where you are, but it's all based on fastener diameter and static length.
#173
Which poly parts did you guys install? Mine Figs, came with spacers for the bolts. The bushings have no flange so they push through from either direction. Adding to that, the front mounts are also slotted at the frame about 20 to 25mm so the diff can accidentally be turned or slid fore / aft from its original location.
#174
#175
Thing is, Figs could have done a better job locating the diff. And not that I plan to ***-end an immovable object at 120mph, but the OEM flange on the bushing serves a couple of purposes.
#176
Tech Info Resource
Figs didn't square your subframe with the chassis centerline. You were supposed to do that.
viprez586 (08-17-22)
#177
If you manage to destroy the figs bushings maybe you're beating the living snot out of it.
JT2MA71 (08-22-22)
#178
All this time I've been mentally prepping to grind the case to fit the LSD and guess what, the OS-Giken slid right into the case without having to relieve or open the case up near the bearing cups. Expecting I'd be taking the spool in and out a few times, I printed some bearings, so I didn't ding up the real ones.
I'm guessing the 350 having a fewer clutches (8 total), perhaps it makes it smaller allowing it to fit here unless the 2011 up case is actually more accommodating?
PS - it was 36F in the garage and the ring gear slid only with minimal interference so I tossed a couple bolts in it and slid it in the case. Now to take it apart, clean it and do it for real. And to your point, holding the ring while putting the final turn on them bolts seems unfriendly and I'm reluctant to use the impact on those bolts.
Does someone have a picture of the IS-F OS-G, I'm curious what is different since this rear diff housing has so many applications.
#179
Here’s an IS F OS giken TCD on a 2014 IS F housing. Don’t mind the red arrows and circles, I had to send that picture to someone asking what a bearing race is.
The following 2 users liked this post by JT2MA71:
2013FSport (11-20-22),
lorenr (11-21-22)
#180
Just got my '08 IS-F and looking to add the LSD ASAP and also want the 3.13 gears. I'm looking at options and think I have it narrowed down to 2 different options:
1. 2021 RC-F Differential with OEM Torsen Diff + 3.13 gears already installed.
- Part # 41110-24270 (incorrectly listed as 2014-2020 Lexus Differential Assembly)
- Cost is $3,599.91 but would be a "direct swap" with minimal labor costs
- Not likely to find a wrecked 2020-2021 RC-F Differential anytime soon
