Yet another ISF to GTR thread
#46
sorry about that, I fixed the above link...please ignore "holy smokes"
#47
Can't beat launch control on the GTR, shoots out the hole quick as sh!$
#48
Got my car back from automobilia auto salon in ct and they did an amazing job! Highly recommend them!3/4 of the car is done in expel and the whole car including wheels and calipers was done in ceramic pro. Website that I bought my front license plate mount from ended up using a pic of my car for the website.
http://www.cravenspeed.com/nissan-pl...e-plate-mount/
#51
there are so many good deals on modified gtrs on nagtroc! I wanted to start stock since there is a bunch of warranty left. Thinking of doing a mid pipe soon for a little more growl, and then I will hear the car instead of the transmission which sounds like a dryer with rocks in it at low speeds.... one annoying thing is how terrible the backup camera is on my car. At night I can barely see a thing
#55
one of the reasons I got the 15' is because that's when they softened the suspension a little. Probably not as nice as the 17' but pretty good. Maybe my transmission will grenade itself under warranty and I'll get a 17' trans! here's for hoping!
#57
#59
They are not Carbon Ceramic rotors, STD cross drilled Iron rotors, no other OEM options. OEM are expensive and they burn up pretty quick. J hooks and other HD iron rotors are prefered when doing the OEM replacement, or do the Carbon Ceramic conversion using the Zr1 OEM brembo rotor. At minimum that conversions $8,500+.
You buy a GTR; all of a sudden you find a way to afford/justify parts because power is so easily made and it becomes so slow after a couple months of ownership and the cycle repeats after every mod(s). With a GTR, if you have to ask about affording it, then dont bother owning one. It's the least expensive car to own with the blend of everything that it does/has. I just dropped $3600 on a billet front diff case. Breaking two OE cast ones, I felt it was time.
~Dv8
#60
~Dv8
~Dv8
