Yet another ISF to GTR thread
#61
They are not Carbon Ceramic rotors, STD cross drilled Iron rotors, no other OEM options. OEM are expensive and they burn up pretty quick. J hooks and other HD iron rotors are prefered when doing the OEM replacement, or do the Carbon Ceramic conversion using the Zr1 OEM brembo rotor. At minimum that conversions $8,500+.
You buy a GTR; all of a sudden you find a way to afford/justify parts because power is so easily made and it becomes so slow after a couple months of ownership and the cycle repeats after every mod(s). With a GTR, if you have to ask about affording it, then dont bother owning one. It's the least expensive car to own with the blend of everything that it does/has. I just dropped $3600 on a billet front diff case. Breaking two OE cast ones, I felt it was time.
~Dv8
~Dv8
I work at T1 Race Development so I see the vicious cycle that our customers go through thinking they'll be happy and then coming back for a bigger build!
#63
Mitch is one of my good buddies and one of the main reasons I always wanted an ISF. His GTR absolutely killed it this past weekend!
#64
I would rather set a goal for the car and focus the build around that, but everyone is different.
#65
There are so many good deals out there on fbo gtrs and custom builds as well. for the record I absolutely love my 15' and am having so much fun!...even in the crappy weather
#66
You work at T1? Wow, I'm jealous.... you guys build some of the sickest GTR's in the country! Im looking to pick up a GTR later this year and my hope is to find one that has already been fully built by T1. Keep up the good work!
#75
