Yet another ISF to GTR thread
#91
The rotors and pads were about $1200 they are better than OEM and they are simple enough to do yourself or you can pay a local shop to do it and it's inexpensive
#94
#95
I have heard GTRs are super expensive to track due to consumables (tires, brakes, etc). I agree though, there are ways to save a buck on maintenance. ISF brakes from the dealer cost a lot, but getting OEM parts from other sources reduces the price significantly.
#99
I guess you would have to define "similar car". Having 335 tires out back and 275's up front makes for an expensive tire job...especially when you run quality tires such as the MP4. Front brakes alone will run you a grand... if you do them yourself. Fluid changes are more complex than most cars so if you dont do them yourself (you should fill comfortable working on cars if your going to attempt to change all the fluids) and you pay someone to do it, it will run you about $1200. So yeah, I guess you would have to define "similar cars".
#100
Maintenance is a lot on these cars (to me), that’s no secret. But compared to its competition, it’s considerably less, all relative. Rotors aren’t cheap, tires aren’t cheap, and transmission fluid/service every 16k on the older cars is over 1k a pop. I also suck through gas in it getting no better than 16mpg. It’s better as a weekend car so you’re not racking up the mileage and wearing out the replaceables so often.
#101
no its not expensive , if u know where to buy oem parts and change your own oil or differential change yourself every 36k miles. Tires i'm running 335 and 285 since pss is now discontinued ps4 has 345, tirerack got 200$ on Visa discount and dont forget Mr rebate as well. I'm on corn juice so a gallon is like 2.39
Lots of ppls are daily them , i lucky enough to have ISF as daily and GTR as weekend car
#102
Lots of ppls are daily them , i lucky enough to have ISF as daily and GTR as weekend car ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
#103
#105
Yea look at all the possibilities with tuning the GTR...........like the clip below this is just a FBO + a little extra mods and BOOM! 3,046hp ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
