Anyone have this problem?
My sides are all sandblasted from road debris. There's no deflector/mudflap for the front wheel so everything just heads to the car.
Yep, tons of rock chips right around the front of the rear wheel arch. I don't think much can be done about it unfortunately unless you want to put mud flaps on your car.
Are you running wider or more aggressive rims/tires. I'm worried about this as well when I install my new rims. I don't seem to have this problem currently with '08 OEM wheels and OEM size tires.
I'm running wider wheels/tires so I know that's for sure a problem. On my old S2K I did a simple mud flap from a commercial rubber molding, I think I may redo the same if no one has a solution.
