Will the ISF run well with a blend of e85?
Old 11-11-16, 06:56 AM
  #181
Vervish
Vervish's Avatar
Originally Posted by JDMV8
...? Whatever you have left to fill up, divide by 4, and that's the e85 you throw in.
Did this have to be explained? lol
thats the challenge - you never know exactly what you have left to fill up.
Old 11-11-16, 07:42 AM
  #182
JDMV8
JDMV8's Avatar
Well, as long as you have a concentration in mind, you're fine. If you had 25% e85 mixed in previously, add 3 parts gasoline to 1 part e85, essentially increments of four. If you see your tank has 10 gallons left, add 2 e85 and 6 gasoline, or 2.5 e85 and 7.5 gas.
It doesn't matter what you throw in as long as the mixture has the same concentration. This is very basic molecular kinetics.
Old 11-11-16, 07:51 AM
  #183
caymandive
11 Second Club
caymandive's Avatar
Just finished checking the timing with the E85 mix and sure enough timing is higher throughout! Good stuff!!
Old 11-11-16, 07:55 AM
  #184
Joker4096
Joker4096's Avatar
Originally Posted by caymandive
Just finished checking the timing with the E85 mix and what sure enough timing is higher throughout! Good stuff!!
Here's the proof. Reduce knock, increase power. Fyi I don't know how people are getting better gas mileage, mine went down around two mpgs. Which makes sense because you usually need 30% more fuel with full e85.
Old 11-11-16, 08:01 AM
  #185
MileHIFcar
MileHIFcar's Avatar
Great! Can't say I'm shocked as it's inline with our results here, the stuff works and it's an excellent way to aid the tune to get the most out of it
Don't know but my mpg has been about the same as before with straight 91 and more occasions than not it's been about 1-2 mpg higher??? Maybe again altitude has something to do with it but I definitely haven't suffered like I thought I would mpg wise?
Old 11-11-16, 08:10 AM
  #186
caymandive
11 Second Club
caymandive's Avatar
Just updated the attachment and made it an overlay between 93 and 93 mix with E85. I'm impressed!
Old 11-11-16, 08:13 AM
  #187
MileHIFcar
MileHIFcar's Avatar
^^^^^Nice! The overlay says it all doesn't it?
Old 11-11-16, 08:19 AM
  #188
caymandive
11 Second Club
caymandive's Avatar
Yes absolutely!
Old 11-11-16, 08:45 AM
  #189
minator
minator's Avatar
Thanks for the graph overlay cayman! And that is with 93 octane base! I'm sure it is even more significant for those of us that only have access to 91 premium. Great work guys
Old 11-11-16, 09:44 AM
  #190
rselby
rselby's Avatar
I can say that I just did a blend of E85 and 93 , about a E25 and with the RR tune and it seems to really like it.
Old 11-11-16, 09:52 AM
  #191
ljdsong
ljdsong's Avatar
Love the feel of power increase! Thank you guys for bringing this up here in the forum.
Old 11-11-16, 01:25 PM
  #192
MileHIFcar
MileHIFcar's Avatar
Not a problem^^^^I should've made a post about this about a month or two ago but I wanted to have 3-4 months of blending done before I started a thread, so when Idoke started this thread I thought this would be the right time to add my experience!
I'm glad everything seems to be pointing the right direction as far as results go with documentation/data logging to back up claims!
Like I said before I'll be an E85er for life especially @ $1.69 gal, and as long as gas stations carry it I'll never go back to straight 91 octane!
Old 11-11-16, 01:44 PM
  #193
Vervish
Vervish's Avatar
Thanks. I totally understand the logic - the part I don't get is how do you know what you have left in the tank?
Old 11-11-16, 01:58 PM
  #194
Joker4096
Joker4096's Avatar
When the miles to go hit 0, there is about 2 gallons in the reserve.
Old 11-11-16, 02:06 PM
  #195
caymandive
11 Second Club
caymandive's Avatar
I found an app called E85 Calculator on IOS. Just hit the defaults at the bottom, adjust the Gas Octane Rating in my case to 93, select either desired octane or ethanol % and then type in the % filled field. I have it set to 15 gallon tank capacity to account for the 2 gallon reserves. The result at the top shows you how much fuel to ethanol to add for a full tank.
Quick Reply: Will the ISF run well with a blend of e85?
