Will the ISF run well with a blend of e85?
Old 02-14-18, 05:01 PM
  #226
idoke1
idoke1's Avatar
I might as well chime in. I have been running 3-4 gallons of e85 mixed with 91 octane premium gas since the beginning when this topic started. I always filled it up when the gas meter points very close to the E. I have since driven 8k miles and I have to say it has work very well. The engine is ALOT more responsive. I am running with the rr-racing tune with no cats in place. My KCLV is in the 23 range and I can't stress this enough, it's a great improvement over the crappy gas we get here in CA. The only negative so far is it gets less MPG. On average with the blend of e85/91 octane, I get around 15 mpg city and 22-25 mpg on hwy. With 91 Oct, i could get as high as 17 mpg city and 29 mpg on hwy. That's all base off my driving style
MileHIFcar (02-14-18)
Old 02-14-18, 06:00 PM
  #227
eyzz21
eyzz21's Avatar
I got traumatized from running an E30 mixture and blowing my high pressure fuel pump on my 335i. But i guess i can't compare apples to oranges. Will try a small blend this weekend!
Old 02-14-18, 06:17 PM
  #228
minator
minator's Avatar
those things blow if you look at them funny 😂
Old 02-15-18, 07:01 AM
  #229
CBR169
CBR169's Avatar
had a FBO 335i with the same problem along with other problems, sold it to get my first ISF, sold it and whent throught a few cars (E60 M5, FB EVO), and getting another one today, gotta say the ISF is the best all around car but headache free does it most for me
BTW the high pressure pump was common failure and at times covered under warranty
Old 02-15-18, 07:04 AM
  #230
sc3dreamin
sc3dreamin's Avatar
So just to clarify, the ISF ecu is smart enough too sense alcohol content (e85) and adjust the tune accordingly?
The stoich point of Ethanol is way different than gasoline
Old 02-15-18, 08:22 AM
  #231
liquidtek
liquidtek's Avatar
I think to some level it is but only adjusting incrementally. Going from 91 to e70 isn't suggested, probably need to gradually increase ethanol to that point each fill up. I've been adding a gallon more of e85 each fill up and trying to data log the lambda levels from the o2. But since its winter here in CO the process isn't going to quick. Like a few of the other mile high guys I been running e30 blend for over a year and my KCLV numbers were far better than just 91.
Old 02-15-18, 05:31 PM
  #232
ImportISF
ImportISF's Avatar
Same here lol, the fuel injectors gave out within a month after trying E85 on my 335i. That was the most expensive repair during my ownership
Old 02-15-18, 07:46 PM
  #233
sc3dreamin
sc3dreamin's Avatar
Naturally, E85 has a higher octane rating and much better resistance to detonation than 91 octane
Old 02-15-18, 10:23 PM
  #234
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,975 Likes on 2,405 Posts
No. It isn't. Lexus does not recognize any fuel with more than 15% alcohol content and the seals in the fuel system are not going to tolerate more than 15% alcohol in the long run regardless of "I ran it for xx,xxx miles without issue".
Old 02-15-18, 10:26 PM
  #235
Htony
Htony's Avatar
Manuals of all vehicles I have driven since '90s required premium fuel. They states in case of Ethanol blended fuel,
I recall no more than 10%. Some are classified as Flex fuel vehicle whatever that means. I never had one of this.
Old 02-16-18, 07:18 AM
  #236
AndrewISF
AndrewISF's Avatar
I've read some of the long term effects of running ethanol is the affect it has on rubber components. Now, seems like most folks are running an e30 blend opposed to e85 so I can see it taking longer for the effects to present themselves. Just wondering if anyone has experienced any of the negative affects of running a higher than manufacturer recommended blend.
Old 02-16-18, 08:13 AM
  #237
sc3dreamin
sc3dreamin's Avatar
Gotcha, I didnt think it would but have been reading about people running it multiple times on this forum
Old 02-16-18, 09:55 AM
  #238
jdmSW20
jdmSW20's Avatar
That's where I always stood on it as well, the long term effects that high of alcohol content will have on components not rated for that high of content. Kind of like folks who run e85 with walbro 255 pumps and wondered why it ate itself after long term use
Old 03-03-18, 12:40 AM
  #239
glerink
glerink's Avatar
Appreciate all the daredevils since 2016, just finished reading this whole thread.
Amazing information maybe I'll give it a go one of these days I got a local gas station that has e85
Old 03-04-18, 01:26 AM
  #240
Bigjon3475
Bigjon3475's Avatar
Why not just get a water/meth injection kit instead of running a fuel that’s not recognized as compatible with the car? Typically they’re used on forced induction applications but they’re also made for MAF/MAP NA applications and water/meth is pretty cheap compared to replacing fuel system components. Snow Performance, for example, says a 3 qt system will typically last for about one full tank of gas. It might be more annoying to fill up with each gas refill but it has to be less annoying than replacing fuel system components?
Quick Reply: Will the ISF run well with a blend of e85?
