Will the ISF run well with a blend of e85?
Old 05-27-22, 08:30 PM
  #361
RRRacing
Sponsor
RRRacing's Avatar
Received 1,396 Likes on 639 Posts
Originally Posted by dannyk1113
So how did you guys actually obtain the tune, am I to contact RR to get started with the process? Could anyone provide some guidance? Any need for supporting mods? Would the tune be taking in consideration any other mods or purely fuel?
thanks all
The answer that IH8RICERZ gave is as good as it gets. That was a pretty spot on explanation. Feel free to give me a call any time to discuss. 484-756-1777. If you think you're good to go, it's as easy as ordering online. It may not be a bad idea to do a tuned intake with the tune that way you have a little more power and a tune that you don't have to revise down the road if you decide to do the intake later on.
-Justin | RR Sales
​​​​​​https://www.rr-racing.com/RR-Racing-...isfitk0003.htm
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Online Store: www.RR-Racing.com
Email: Contact@RR-Racing.com
Phone: 484-756-1777
Facebook : Youtube
Old 05-26-24, 12:28 AM
  #362
Ab175
Ab175's Avatar
Reviving this thread. For those who are blending to e30, what are your long term fuel trims?
Old 06-08-24, 05:16 PM
  #363
Gohanburne
Gohanburne's Avatar
I think blending for 3 years has finally compromised my fuel pump. No indication of it failing, just threw a P0087 (low fuel pressure) out of nowhere. Removed the relay, put it back int, pressures went back to normal, no issues. The following day, made a 1hr trip without issues. As soon as I went to leave, same thing, P0087. Replacing the fuel pump with an AEM 50-1220 but figured I should let others know in case E85 is what caused the failure. I only put 4 gals in and mix the rest with 93.
Old 06-08-24, 05:56 PM
  #364
caymandive
11 Second Club
caymandive's Avatar
One of the reasons I stopped mixing e85 awhile ago. Was afraid of causing problems with the fuel system. Been using Boostane Professional Octane Booster in my fuel instead and couldn't be happier. I mix between 2 and 3 ounces per fill up (to achieve 96 octane), so one bottle (32oz) goes a long way. Car has been running great on it and my KCLV levels are higher and my fuel economy has improved over mixing e85. RR-Racing sells the product but you can also get it on Amazon.
Old 06-08-24, 07:05 PM
  #365
semnosNSX
semnosNSX's Avatar
stupid question- Boostane comes in a large 32oz can. How do you accurately measure out 2-3 oz and pour that into your tank while at the gas station filling up?
Old 06-08-24, 07:11 PM
  #366
caymandive
11 Second Club
caymandive's Avatar
I keep the can along with a measuring cup a funnel and disposable gloves in a sealed plastic bag in the trunk. The stuff smells horrible, which is why i keep it sealed in a bag and I'm not about to let the stuff touch my skin hence the gloves.
Old 06-08-24, 07:13 PM
  #367
semnosNSX
semnosNSX's Avatar
Gotcha! Thanks for the info! I’ll give it a try!
Old 06-08-24, 07:43 PM
  #368
flowrider
flowrider's Avatar
Received 1,906 Likes on 1,343 Posts
I've been using Lucas Octane Booster for over three years now. With the crap gas we get in Arizona it's well worth it. KCLV went from 19 to 23.
Lou
Old 06-09-24, 02:32 PM
  #369
iH8RICERZ
iH8RICERZ's Avatar
Lou
How many oz of Lucas Octane Booster are you using per fill up?
Old 06-09-24, 02:38 PM
  #370
caymandive
11 Second Club
caymandive's Avatar
Lou
Yeah I see the exact same. KCLV goes from 19 to 23.
Old 06-09-24, 03:56 PM
  #371
flowrider
flowrider's Avatar
The full 15 oz bottle.
Lou
Old 06-10-24, 09:59 PM
  #372
ChpEng
ChpEng's Avatar
Default US DOE/EPA E15 Fuel Waivers
Last weekend, I watched an east coast PCA meeting video where Lake Speed Jr mentioned that nationwide DOE/EPA waivers have been issued for summer blend gasoline. These waivers allow refiners to exceed the E10 requirement and use (up to) a 15 percent ethanol blend. I checked, and he is correct, nationwide waivers have been issued for the past two summers (2022-2023) and again this summer (2024).
Just prior to Lake's discussion point, Charles Navarro recommended using a fuel additive with every tank for older ("pre-Boxster") Porsches.
Bringing this up here for awareness. MY11 ISF fuel cap specifically states that fuel should not exceed E10. The waivers means we in the US are likely getting E15 and have been the past two summers.
Fuel Waivers | US EPA
Last edited by ChpEng; 06-10-24 at 10:01 PM. Reason: grammar, punctuation, spellin'
The following 2 users liked this post by ChpEng:
mike33 (06-13-24), xdejablu3x (06-11-24)
Old 06-12-24, 08:44 PM
  #373
Gohanburne
Gohanburne's Avatar
Just an update...the fuel pump was faulty. I also had installed it incorrectly and it was sitting on the bottom of the carrier not picking up fuel. I had to use the OEM strainer to fit the carrier. It starts and drives great...but when I reach about 5,000rpm on a pull it will putter. No CEL, but there is definitely something wrong at 5K rpm. It could be the gas though. I'm going to fill up with only 93 the next fill up and disconnect the battery to start from scratch and see if that fixes whatever is going on. My spark plugs are basically brand new so I didn't think it was them.
Edit: I replaced the OEM low pressure fuel pump with the AEM 50-1220.
MileHIFcar
GS F (2016-present)
01-13-19 07:52 PM
mmartin061
IS F (2008-2014)
31
11-06-16 07:26 PM
Weapon F
IS F (2008-2014)
62
04-14-15 06:09 AM
Herblenny
IS F (2008-2014)
20
01-29-13 08:34 PM
y2ks2k
IS F (2008-2014)
03-16-08 04:40 PM
Quick Reply: Will the ISF run well with a blend of e85?
