Will the ISF run well with a blend of e85?
#91
Im sure it helped somehow. The car has alot of knock when the intake temps are high. 90+ And i know in texas... its hot lol. The added octane should keep your values up just a hair in accelerated temps.
#92
Just from my experience I noticed the quickest ECU learning when switching to blended fuel when I reset the ECU. I drove around a bit without resetting my ecu and it took awhile before I saw KCLV improvement. But after resetting it seemed to compensate for the changes much quicker. I had started a thread about the high altitude and the effects on the KCLV. I'm probably one of the few if not only person with both company tunes. Rafi was beyond helpful and quick at sending me the tunes and recommended blending thanks to other local guys constant data logging with it. As for TTFS, well I eventually received a 'revised' tune from them after much nagging. Pre-tune revision(s) my KCLV were complete garbage. After revisions they were 'acceptable'. After revision + blending it seems to be above average but I'm still yet to get my KCLV into the 20s but much better than previously. Having better luck with e85 than I did running octane booster.
#93
Blended in 3.5 gallons of E85 tonight and topped off with 93. Did some WOT pulls in 6th and 8th gear to get the KCLV values up - not sure where they're at currently as I don't have tech stream. Car feels like it has some extra grunt in the seat of the pants. Came home, and reset the ECU and went out for a quick drive 20 minutes ago and there definitely is a difference! Car pulls HARD out of the hole and even walked a cammed fox body Mustang on my drive home
#94
Has anyone had an in-depth look at our fuel system? Here's an example from evolutionm, the OP has used E85 for 3 years straight, 50k+ miles and the factory fuel system looks spotless. This, along with everyone else's feedback makes me feel reassured that we should be OK and we could be on the dawn of a new chapter of ISF tuning. I smell an E85 tune as a strong potential, *hint hint*, Rafi ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
http://www.evolutionm.net/forums/e85...years-e85.html
#95
Blended in 3.5 gallons of E85 tonight and topped off with 93. Did some WOT pulls in 6th and 8th gear to get the KCLV values up - not sure where they're at currently as I don't have tech stream. Car feels like it has some extra grunt in the seat of the pants. Came home, and reset the ECU and went out for a quick drive 20 minutes ago and there definitely is a difference! Car pulls HARD out of the hole and even walked a cammed fox body Mustang on my drive home ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Rafi did say he ran out of fuel with the S/C set-up, but he didn't go into details on how much boost the car was running when he finally hit the max duty cycle or max on the fuel pump? Was it 8,9,10lbs of boost? Nobody knows at this point, what he did say is that he will be working on an injector upgrade (all 16 of them) this winter and hopefully that will allow more boost and/or E85@ 100% possibly??
Your right good times to be an F owner!
#96
Remember there is a limit to how much you can blend E85 into the ISF as the short/long term trims will max out and cause a CEL.
I would have thought this car, whilst could benefit from a touch more octane than pump in some scenarios, would not benefit more than a E20 mix (with a 93oct base) - remember the ISF is still N/A.
I've ordered a techstream cable and will try various mixes and see its effects on KCLV and actual full load timings.
#97
had A VERY similar experience yesterday(with immediate ECU reset).
i was luckily empty so added 4 gallons E85 then topped off with 93. Did the ECU reset before starting the car. Drove off and immediately did low (sub 3 k 8th gear) and high (3k to redline 4th) and BINGO.
car pulls HARD out of the hole and engine revs with an alacrity that I frankly haven't ever seen before.
Im IHET and THIS IS my fueling option from now on. Was using octane booster, this KILLS THAT BY A MILE, and is cheaper to boot!
NOT A subtle, very noticeable immeadiatly after pulls 5 total.
doesnt hurt I can fill up a block from my house
#98
doesnt hurt I can fill up a block from my house![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
#101
^^^^^^^^^^Yea I remember reading Juan Medina's thread last year but had barely gotten my car last year and was still learning about the car so didn't think much about it. But your right didn't seem like anyone in the community if they were blending didn't share about their experience?
I have been doing this since July, I wanted to test this for a while before I made a specific thread about blending E85 so my results weren't premature. But when Idoke asked the question to start this thread I figured now was the time to jump in and share my experience and knowledge about this subject.
The E85 should act as a crutch/Bandaid for your next track session when your seeing temps in the 140's when your staging!
#102
In that thread, Mr Slay had ran into issues with his mix. i think that can help answer questions of how much e85 is safe to add until the car starts getting angry.
#105
Awesome!! Report back with results, pretty sure your going to love it! Gotta love that pic with the octane rating
You right the smell isn't as bad I assume as if your running straight petrol, the leaning out affect probably affects the smell for the better?
