What part to replace to get rid of drone?
Old 11-12-16, 06:31 AM
  #46
clarionguy
clarionguy's Avatar
I've been running Joez exhaust and hps intake for a long time. During this year I made a separate attachment for a straight pipe.
No doubt both had the hum at highway cruising speeds unless you are over 80-90 mph.
Also does everyone get a loud volume increase at idle when there is a load on the system. Eg Air conditioning and headlamps? When I turn off the HVAC and lights the car is whisper quite.
However I wish this was true during cruising.
Old 11-12-16, 11:22 AM
  #47
nks979
nks979's Avatar
Yes mine with borla/bazooka goes silent with no electrics running, also drops to about 400-450 rpm idle, I just leave things on even when they aren't necessary now to prevent that.
Old 11-14-16, 07:56 PM
  #48
jadeboy
jadeboy's Avatar
I just brought 4 rubber exhaust dampers on Amazon from China.. it will probably take a month to arrive. Will solder a metal bar and mount it onto the side of the mufflers to see if it reduces vibrations even more..
Old 06-27-19, 06:13 PM
  #49
juliusdx
juliusdx's Avatar
Um... any updates on this ?
Just did a muffler delete, loving the sound everywhere except around 2k RPMs.......
Old 06-28-19, 12:07 PM
  #50
VanCityLS4
VanCityLS4's Avatar
Originally Posted by Diesel350
Remeber that you can't really block a 133hz frequency range because it is a natural resonance frequency. Just think about an LS460 for example that is heavily insulated with dynomat material. If you straight pipe your exhaust system on that car and don't do it right you'll get pretty bad drone and all the insulation in the world won't cancel out the resonance coming into the cabin area.
This is right here. The dreaded 1UR/2UR drone.
On my 1UR I first installed a 2.25 Magnaflow axle back, it wasn’t enough. Quickly I tossed it and ran a custom factory mid pipe with deleted secondary’s, new H pipe in 32” section with OEM resonators. It bolted up to new 2.5” Black Widow chambered mufflers. The 1700-2200rpm range ruined the car if there was anything more than a slight uphill grade. No amount of insulation will get rid of that frequency. I looked into adding helmholtz chambers but I’m happy I didn’t. After a few months I went back to stock axle back and the custom mid pipe was hardly audible. Even the downgrade in horsepower was noticeable.
Recently I added 2.5” Vibrant Performance mufflers. What a difference, next to no drone and all the noise I was looking for (I still want PPE headers). I couldn’t expect a better balance. Ill have to say keeping factory resonator in place helps keep the peace (when everyone is usually cutting them out) I looked at many JDM axle backs and many had a loop system ($$$) or somewhat of a tailpipe. I think its a factor in cutting out unnecessary noise/drone. I had my fabricator move the muffler forward and add a 5” tail section.
I’m driving in M mode with Sport daily now. The SPDS is so much better with exhaust mods..
Old 08-02-19, 01:13 PM
  #51
Leander311
Leander311's Avatar
There's a thread somewhere where I describe installing a couple small motorcycle "SPL killer" inserts in two of the four Borla outlets, and my acoustical engineering app was registering something like 6-8dB lower. Even dynoed them and think it only lost like 5-6hp? Best $20 and 20 mins I've spent on the car.
Something like this:
Amazon Amazon
MileHIFcar (08-05-19)
Old 08-03-19, 10:44 AM
  #52
xdejablu3x
xdejablu3x's Avatar
Has anyone tried welding on a bracket to the rear left muffler that holds a rubber absorption dampener? The OEM exhaust has a bracket on the back of it that holds a rubber dampener in the back. I'm thinking about switching it over to my setup to see if drone goes away or not since I'm doing a muffler delete on the catback and will eventually buy new headers. I assume they put it on the side due to the piping being longer for the left muffler. Most likely has to do with the harmonics.
Old 08-03-19, 12:03 PM
  #53
Vervish
Vervish's Avatar
I have the xforce varex with the smartbox. Smartbox app allows you to precisely tune different rpm bands to eliminate drone.
As an example - I have mine set to be fully closed (quiet as stock) from 500-2000 rpm, 2000-3000 it’s 30% open, 3000-4000 60% open and full open beyond 4,000rpm. It is 100% customizable based on rpm, throttle opening and speed..
mike33 (08-03-19)
Old 08-03-19, 12:27 PM
  #54
SubOrbital
SubOrbital's Avatar
How’s the quality of the Xforce? I’ve been considering one, though I’m already using my ODB2 port for a bluetooth dongle so smartbox isn’t for me.
Old 08-03-19, 12:53 PM
  #55
Vervish
Vervish's Avatar
Overall i think it is very good considering the price point.
Here is photo of new muffler I installed recently next to the old. On the right are my 2.5 year old mufflers - they still polish up nice, that’s just road grime.
Old 08-03-19, 01:40 PM
  #56
Wh0pp3r
Wh0pp3r's Avatar
Is it just me. or do those look like window motors?
Old 08-03-19, 01:48 PM
  #57
Vervish
Vervish's Avatar
Pretty sure that is exactly what they are.
Slyryan
IS F (2008-2014)
17
01-25-16 07:14 PM
O1GS43O
IS F (2008-2014)
10-02-15 12:43 PM
FD3SISF
30
12-27-13 12:31 PM
captdewalt
IS F (2008-2014)
13
07-20-13 05:23 PM
infate
Performance
08-08-12 09:32 PM
Quick Reply: What part to replace to get rid of drone?
