2009 Ride Softening without changing coilovers
Hi all you suspension experts.... As everyone knows the ealry ISF's ride a little harsh. Is the stock suspension adjustable at all? Without changing yhe coilovers?
We are replacing our VW TDI Golf (buyback program) with an '08. I gotta tell you that the Golf is LOUD with a go-kart ride. My wife and I are super happy with the ride our new ISF delivers. It reminds me of our 1997 Miata after we put on all-season radials instead of "sport" tires: quiet, firm ride but still fun to drive around corners for miles and miles without ear and a$$ fatigue. It's all a matter of perspective...
I haven't put new tires on and since it's my wife's DD she has it at work now I don't know what brand/model came with it. I was relating the current ride with the existing tires to our Miata with all-season family sedan radials. I'll post brand/model later.
I did notice that the air pressure on all 4 were 28-33psi. Sidewalls say 50psi. I filled them all to 50psi and my wife actually noticed the tighter feel of it (she didn't know I had filled them!). I still say the ride is much more enjoyable and quiet than the Golf TDI or Miata with sport tires ever was.
This sounds reasonable:
"To gain tire life, starting with 10% under the maximum, listed on the sidewall often gives improved tire wear, with a P-metric tire. For example, a tire listed at 44 PSI could start with about 40 PSI. From this point, we can adjust pressure down to the placard rating if ride quality is too harsh.
With a load rated (not P-metric) tire this method may give an extremely harsh ride. On these tires start with the tire placard recommendation and adjust upward until a good compromise is found. In both cases we should never exceed the minimum or maximum specified air pressure."
But in the end, I believe I'll use www.firestonecompleteautocare.com/tires/tire-pressure/inflation/ which recommends 36 front, 37 rear - basically the door placard.
My world has been rocked.
...and Bridgestone Potenza RE050A
ALL my life I was told to fill the tires to the sidewall pressure. So after reading all the threads about what you guys run as tire pressure I can say you're all wrong or I can say 'damn, have I been wrong for 3 decades?' I believe it's the latter. After visiting many, many, many tire professional websites, I couldn't find anything to support my argu
i hamaximum, listed on the sidewall often gives improved tire wear, with a P-metric tire. For example, a tire listed at 44 PSI could start with about 40 PSI. From this point, we can adjust pressure down to the placard rating if ride quality is too harsh.
Your link doesnt work?
