Lets See Your Garage
Old 12-26-16, 11:06 PM
  #61
Bavarian
Bavarian's Avatar
That is a happy place for men. It is really wellness for the soul.
Old 12-27-16, 07:23 PM
  #62
I8ABMR
I8ABMR's Avatar
Old 12-28-16, 01:42 AM
  #63
SRTISF
SRTISF's Avatar
Originally Posted by mikersoft
Christmas present for my garage. I want to be able to work in my "safe space" year-round.
-Mike
Im gonna be "that guy".. Im an electrician/ Electrical Engineer..
You got the wrong wire man.. you need 10-3 Romex for a 240v circuit, assuming you you are only going up to a 30A circuit breaker (looks like a 30 in the pic).
10-2 is only good for 120v. Unless you plan to use the white wire as your L2 and use the ground as your neutral.. (wouldn't recommend that)
Post pics once its done! Been thinking about putting in a AC/ Heater in my garage too
Old 12-28-16, 09:54 PM
  #64
tsx2isF
tsx2isF's Avatar
Old 12-28-16, 10:47 PM
  #65
Apexsports
Apexsports's Avatar
Old 12-31-16, 10:19 AM
  #66
Gymkata
Gymkata's Avatar
The El Camino looks bad ***.
Apexsports (01-02-17)
Old 12-31-16, 10:36 AM
  #67
Rickna
Rickna's Avatar
It's a beauty!
Old 01-02-17, 11:23 AM
  #68
mikersoft
mikersoft's Avatar
Yeah, it's a 30A breaker.. I read the heater draws a little over 20 amps on the highest setting. I did use the white wire as my second hot lead, since there's no call for a neutral with this set-up (two hots & ground only). Was your recommendation to not do that based on safety concerns? If so, I did apply black heat shrink to the white wire so that nobody else would mistakenly think it's a neutral. Also, my neighbor is a journeyman electrician, so I usually have him sanity check my DIY work to make sure I'm not doing anything incorrect or dangerous.
So far, I like it.. It makes pretty good heat for its size. However, it's obviously going to be less effective in a non insulated space, so now my next project is to close in the rafters and add insulation. My first step was to add a folding attic ladder since I want to maintain easy access for storage.
-Mike
Old 01-02-17, 01:57 PM
  #69
Rickna
Rickna's Avatar
The attic ladder is an excellent idea. Every time I need to get to the loft I have to use a regular ladder.
Old 01-02-17, 07:11 PM
  #70
ThisOldNSX
ThisOldNSX's Avatar
No ISF yet.. Soon though...
Old 01-03-17, 06:18 AM
  #71
Lmood
Lmood's Avatar
is that a prelude? ha got some good memories in one of those.
Old 01-03-17, 06:29 AM
  #72
ThisOldNSX
ThisOldNSX's Avatar
Sure is. Its on daily driver duty for now. Probably gunna trade it an the s2k in for an ISF.
Old 01-10-17, 01:58 PM
  #73
Damage
Damage's Avatar
Old 01-10-17, 04:19 PM
  #74
Rickna
Rickna's Avatar
Originally Posted by Damage
Beautiful ponies in your stable.
Old 01-11-17, 12:04 AM
  #75
21ce
21ce's Avatar
Quick Reply: Lets See Your Garage
