285-30-19, choosing my offset
Old 11-22-16, 01:30 PM
Max16
Max16's Avatar
Default 285-30-19, choosing my offset
I'm there at my offset.
I want to run a 285-30-19 on a 19x9.5 rear
I'm slightly dropped and my fenders are shaved.
I think I can go with a +40 from what I read but hesitating on going to a +45
What do you guys think?
Old 11-22-16, 01:55 PM
Vervish
Vervish's Avatar
+40 should work out fine, I think you could even go +35 if you want to be more aggressive. I defer to the fitment guys tho.
Old 11-22-16, 02:01 PM
Jondls33
Jondls33's Avatar
im running 275/30/19 on a 10.5 +30 offset, I rub a little on big dips and im lowered on bc coilovers, fenders rolled.
Old 11-22-16, 02:02 PM
Max16
Max16's Avatar
I'm running 20x10.5 +45 right now but with a 275/30
No rub but really no place for anything more.
I really want to fit the 285 or even a 295
Old 11-22-16, 03:35 PM
jspecvtec
jspecvtec's Avatar
I have a 10.5" 285 on rear +43 offset. My fenders are shaved and no rub. Still a tad bit of room, possible to go 295 but not sure I can with the wider running mpss tires. 285 is probably a bit too much for 9.5" wheels. I think 10 or 10.5 inch will fit better for 285
Old 11-22-16, 05:03 PM
Max16
Max16's Avatar
285 is ok on a 9.5
It's on the low side but ok. 285 is made to fit from 9.5 to 10.5
The wheel I decided to go with is only available 9.5 or 11 and the offset won't go to +60 in the 11"
Are you dropped?
Old 11-22-16, 05:05 PM
newgsman
newgsman's Avatar
I tried out RCF wheels 19x10 +41 with 285/30/19 and I would rub anytime I hit a bump in the road or make a quick turn. My car has stock suspension. If you are lowered you will probably rub on uneven pavement even with a 9.5" wide wheel.
Old 11-22-16, 05:12 PM
Max16
Max16's Avatar
You are 1\4 inch more toward the outside with a 10in wheel.
Are your fenders stock?
Old 11-22-16, 07:16 PM
jspecvtec
jspecvtec's Avatar
285 is ok on a 9.5 It's on the low side but ok. 285 is made to fit from 9.5 to 10.5 The wheel I decided to go with is only available 9.5 or 11 and the offset won't go to +60 in the 11" Are you dropped?
0.6" in rear
Old 11-22-16, 09:19 PM
flowrider
flowrider's Avatar
Received 1,909 Likes on 1,345 Posts
I'm running RCF wheels with 295/30s. Your absolutely right on the rub and you describe it well. For awhile my inner lip was rolled and that helped a bit. The lip is now flat against the fender. And the rubbing is greatly reduced to be point of ALMOST being non-existent. I am now extremely happy. The extra meat (255s in front) is IMHO the way the car should come from the factory. Handling, with the F-Sport rear sway and the RRRacing A arm bushing, is much improved.
Lou
Old 11-23-16, 07:46 AM
zmcgovern4
Auto Detailing Master
zmcgovern4's Avatar
Currently running a 19x10 +40 with a 285/30... fenders rolled. Only rub on really big dips in the road. So no rubbing 99% of the time.
Old 11-24-16, 08:06 AM
Max16
Max16's Avatar
Good thanks
I'll go with a 19x9.5 +40
jvjr9902
07-20-15 06:00 AM
scmaluco
SC- 1st Gen (1992-2000)
27
06-11-12 01:17 PM
zetec2vtec
05-24-09 10:55 AM
TTurboPimp
Suspension and Brakes
15
06-06-08 07:03 PM
redgs4
Wheels, Tires & Brakes Forum
04-30-02 12:48 PM
Quick Reply: 285-30-19, choosing my offset
