Borla exhaust installed
#46
Borla is the greater magnaflow in my opinion. Similar business concept in making affordable yet functional systems. Which, obviously some of that cost is saved via the slip joint connections.
Those that complain about drone when adding headers have to acknowledge that these systems are designed and tested with the factory manifolds 95% of the time I'd imagine. You are adding a variable so have to account for it in your own way.
#47
It's a quality system, but its split into several parts. Any leaks that are "possible" are easily fixed and I am sure customer service could help pay for that. When I had my Invidia catback on my G37, it arrived with a minor issue and the company stepped up to pay for a quick welding fix without issues. However, many people have no had issues with the Borla leaking, simply saying that the connections could allow for that to happen, but it doesn't happen often and even if it does it's easily fixed. This is not similar at all to the exhausts most often sold by ebay that have fitment, connection, and symmetrical issues along with cheap metal used. The Borla looks and sounds like a well designed system although it does have a slight very slight drone when under load without shifting at ~1900-2200 rpm. I hate drone above all, and never stood for it in any of my cars. I always go for the mildest exhausts available while still getting gains and good sound. The drone doesn't bother me too much.
#49
#52
#53
Tech Info Resource
If your car has lived in Texas all its life, you'll be able to do this pretty easily. If it came from anywhere the roads are salted for snow, you won't have any fun at all with this.
None of my cars have lived in the snow belt, so they are all pretty easy to work on. I don't even bother with penetrating oil on the shelf because it's not necessary, ever. My dad lives in Iowa. He has a case of PB Blaster in his shop and goes through it routinely. I'll never live there again if for no other reason than this.
tacosmashr (04-08-24)
#54
I have intstalled my Borla system on jack stands a couple of times. I put it on for a couple of years then I decide its time to quiet the car so I go back to stock then a couple of years later I miss the Borla sound so, back on it goes. Each time I have taken the rear bumper off. I also replaced the bolts once, mostly as a pre-emptive measure. O2 sensors are always abit of a pain but still doable. My car is mostly a fair waither car so that helps.
#55
#56
I installed mine this weekend, and I noticed one side it had something to hang on and then other doesn’t. So when I turn on my car here and there it has a thumping sound, wondering if that’s normal to anyone else or maybe I didn’t tighten the exhaust right or anything. I would like to hear y’all’s experience and know if there’s anything to look out for thank you.
#57
#58
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_5151_713b6485b735c1ce10b89c734ef0316ae324c841.jpeg)
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_5147_a50385cc5d02f653e01aace351f4713662778f5f.jpeg)
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_5146_a8afccd824411cf9880b40ce1c8d1370c4e7e0fd.jpeg)
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_5148_1156a09751b42fa231ad0a6ecc96042d677b4373.jpeg)
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_5149_e82a4d4f37966eef2697f43b8d1f8504d3b6474f.jpeg)
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_5150_dd6c882216b9938ee585fa651386d3dd3946d600.jpeg)
These are the best pics I can take at the moment, it probably won’t show much. But whenever I start the car or drive it it has like a thumping sound almost like a misfire type of sound. On the left it has a hanger holding it up but I did take off a piece of metal that was there to be able to have the exhaust set up there. I also didn’t put the black covers on the bottom fully on its missing a couple of pins so idk if that can be the result. But on the right it’s lower then there other since it has nothing to hang on and didn’t come with one.
#60
I'd get it on a lift or jack it up, pull and push on the piping to see where the pipes are making contact. I noticed when I installed my RR bazooka tips, I had to go further back, loosen up the bands, and adjust the piping a tad for things to line up and/or not rub in certain places.
