Improving KCLV and power...
#31
Seafoam works wonders in all kinds of ways! I've been using it in my 10 years of ownership in my is300. Usually before semi long trips (one where I'll burn thru a full tank of gas there and back), I'll dump an entire can of seafoam into the gas tank! It 100% for a fact, EVERTTIME makes the car idle smoother and improves gas mileage. Another thing that's noticable is the shifts are smoother after a can of seafoam. And before seafoaming, the shifts and idlings seems 100% fine, but afterwards there is a clear improvement.
I've put it in the throttle body a few times to clean out carbon buildup and it def does just that.
I've yet to use it on the F because I was under the impression that the car is too young to need it and that there shouldn't be any carbon buildup in a 30k mile vehicle, etc. But maybe I'm wrong.
And don't confuse seafoam with that crappy GUMOUT fuel treatment they try to sell you Everytime at autoparts stores. It's like $2 a bottle and crappy....Used it once, beating cheap, and felt my car running worse. Seafoam should be around $10 per bottle.
V.
V.
#33
V.
V.
#34
V.
#35
Gumout makes an injector cleaner in the skinny bottle like the Lucas stuff. That product is not so good, the complete system cleaner is a bigger container like seafoam and works really well. I'm actually going to use a bottle in the near future.
#36
Rafi,
I couldn't help but think about the e85 blending thread our forum had awhile ago. Correct me if I'm wrong, I'm wondering if this method would have sufficed for the guys at altitude or sea level? In order to improve the KCLV and power like the e85 blend apparently has been doing.
#38
Will dcguy be going back to 91 or 93 octane and resetting the values? And then trying this method? Thank you MileHIFcar
#40
Physics doesn't support needing more than 91 octane at your altitude. You'll need considerable more boost than those of us at lower altitudes to reach the limits of the fuel you have available. PV=nRT is your friend, not your enemy.
#41
^^^^^Kind of confused by saying that we need considerable more boost at altitude and how that correlates to a KCLV challenged car like dcguy in the above thread? Also how that relates to Ideal Gas Law/Equation?
The E85 blending for us has shown to be useful at increasing our KCLV #'s by increasing the overall octane blend to about 95 (some more than others might be a reference to what you said below about Squish height) and shown to run more timing than other F's here with just straight 91 octane while running the RR tune.
What you said below makes sense and I wonder if that's the issue with guys who have issues raising their KCLV #'s with the tune whether they are at altitude or sea level?
"The other thing you'll likely find with KCLV challenged engines is the deck height isn't optimized so the squish is too great. Squish height is the most critical dimension in a performance engine because it alone determines octane requirements. Get the squish right, and the engine will run ridiculously high compression on crappy fuel. Get it wrong and you'll be scratching your head for years trying to understand why the engine won't run on anything less than the most expensive high octane fuels. Manufacturing tolerance for squish almost invariably puts it in the less than ideal range, and sometimes in the far from good range."
Thx
Thx
#42
I pulled my numbers before the seafoam treatment. 18.2 -3k rpm/ 17.4 +3k rpm. Liquidtek joined me on the seafoam adventure, he held the the rpms at about 1250 while I sprayed the can into the throttle body. Also added the seafoam fuel treatment to a half tank of gas. When it was empty, shut the car off for about 15 minutes to let it heat soak, than drove it to burn it all out. There was a ton of smoke, wouldnt recommend doing this treatment in your neighborhood unless you enjoy worrying your neighbors. I drove around for a bit keeping an eye on kclv values. Still have hard knocking in the 2.7-2.9k range driving my below 3 values down. Planning to check values after i burn through this next tank. (Refilled today) so far not seeing any significant improvements directly after treatment, but ill check back in after this tank. 250 miles to go.
#44
Thx
Thx
At the same time, because you are moving fewer oxygen molecules through the engine on every cycle, you won't make as much power as someone at sea level. Again, basic physics and the universal gas law.
You can calculate all this stuff fairly easily, and if you understand density altitude, none of it should be a surprise.
