Front Brake Systems
Thank you all for the replies! I have read through the full brake thread. Between that and the advice here, I am thinking I want to go with the RB 2 piece rotors and the PM HC+800 for the pads. Has anyone run this combo? The 'Hyper Carbon' compound seems like it should meet the semi-mettalic requirement of that rotor.
Also, I did not see anyone comment on the calipers. Safe to assume that means no one thinks I should be worried about them?
Former Sponsor
Also, I did not see anyone comment on the calipers. Safe to assume that means no one thinks I should be worried about them?![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Also I agree that the calipers are not the weak link or problem in your case.
-Matt M.
We've had several customers use the HC+800 pads with the RB rotors and the only issue we've heard back is that the PMU pads fit a little tight since we tried to maximize the pad thickness and the RB rotors are likely ever so slightly thicker than the OE rotors. To solve this we requested that half of our next batch be shaved 1mm so we will have pads specifically for our customers using RB rotors
No issues at all with that compound not playing nice with RBs metallurgy.
-Matt M.
-Matt M.
I couldn't agree more. You can get OEM rotors really cheap and HC+800 are phenomenal pads. If you track your car, you'll notice how quick these things wear out, so ponying up $1000+ for new rotors is not an option, at least for me.
http://www.ebay.com/itm/Set-of-2-OEM-Replacement-Front-Rotors-Lexus-IS-F-/151733058041?fits=Make%3ALexus&hash=item2353feb9f9:g:afQAAOSwJcZWgne6&vxp=mtr
These come in branded as Brembo, they're not slotted, just cross drilled. I usually use them for one season and throw them out.
Dont know if I can trust Brakenetics since I've never heard of them before (Even tho you've been using them)
I'll see how the Brembo branded ones hold up next time.
Question for related brake work, my front brake is worn out to about 20% left. The front brake is shaking a little bit when I apply the brake at the red light. I've just ordered the stoptech sport pads to replace by this weekend. Do I have to resurface or rotor the brake disc or is it ok to just replace the brake pads? I hope the shaking problem will go away for new pads.
Question for related brake work, my front brake is worn out to about 20% left. The front brake is shaking a little bit when I apply the brake at the red light. I've just ordered the stoptech sport pads to replace by this weekend. Do I have to resurface or rotor the brake disc or is it ok to just replace the brake pads. I hope the shaking problem will go away for new pads.
ISF350 (01-12-17)
