Front Brake Systems
Old 01-12-17, 09:03 PM
  #31
flowrider
flowrider's Avatar
Received 1,922 Likes on 1,356 Posts
Originally Posted by ISF350
Question for related brake work, my front brake is worn out to about 20% left. The front brake is shaking a little bit when I apply the brake at the red light. I've just ordered the stoptech sport pads to replace by this weekend. Do I have to resurface or rotor the brake disc or is it ok to just replace the brake pads? I hope the shaking problem will go away for new pads.
Before you do any resurfacing, you need to measure the rotor's thickness. If it's too worn, and my guess it is, you need new rotors. Resurfacing rotors is rarely necessary unless they are grooved or have developed high spots. Sounds like you may have developed a high spot or two. In any case measure rotor thickness before doing any cutting. Rotor's are not really an expensive item, and in almost all cases where there is some doubt, replace.
Lou
ISF350 (01-13-17)
Old 01-13-17, 05:17 AM
  #32
bbong
bbong's Avatar
Lou
Lou, was going to suggest the same thing, I never bothered with resurfacing my rotors either, they're so cheap that I usually get a new set and never let existing one develop any unevenness.
I posted a link to rotors I always get, just get them and don't bother with resurfacing, as it'll cost 1/2 of new rotors and they may already be worn out to the point that cracks around the cross-drills may be connecting or edging the rotors.
Old 01-13-17, 08:26 AM
  #33
Piston1047
Piston1047's Avatar
Originally Posted by eternallx
Thanks guys, I've been using Raybestos rotors paired with HC+800 for Street/Track days and they've been lasting me about 6 Track days before I gotta toss them.
Dont know if I can trust Brakenetics since I've never heard of them before (Even tho you've been using them)
I'll see how the Brembo branded ones hold up next time.
For what it is worth, I have run these rotors at the track (road Atlanta) and they hold up better than OEM cross drilled, so, there's that. Also, I wouldn't put to much weight on branding when it comes to rotors, as long as they use a GS3000 or higher casting grade. A lot of manufacturers just buy centric or raybestos anyways and drill or slot them to their spec. Iv'e driven multiple types of vehicles in many scenarios and rotors just aren't that complicated for a HPDE or amature racer. It's casting a solid piece of metal not "rocket science". I look at the structure and material as more important and I have deemed a slotted rotor (that doesn't got to the rotors edge) of brand X versus the OEM drilled, is superior when materials are equal. I'll keep everyone posted on how well these hold up on continued track use.
I would also recommend having a dedicated set of rotors/pads for track and one for street. It's more initial cost but in the long run it saves money, since you don't wear out the expensive track set as fast and your milder pad street setup also lasts longer.
Old 01-13-17, 09:18 AM
  #34
SpeedFreaksUSA
Former Sponsor
SpeedFreaksUSA's Avatar
What pads were in the car before? If you're getting juddering when applying the brakes you likely have small pad deposits on the rotor face and the problem will persist with new pads unless they are an aggressive track pad which is abrasive enough to wipe away the deposits at cold temps (the stoptech streets are not). As others are recommending- new rotors can be had for cheap and more often than not resurfacing just isn't really worth it if you're paying more than ~$20/rotor for resurfacing. If you were planning on taking it to a dealership to have them resurfaced I can pretty much guarantee you'll be walking out of there with a bill that would have covered, or at lest been within spitting distance of some new cheap rotors.
-Matt M.
ISF350 (01-13-17)
Old 01-13-17, 03:44 PM
  #35
ISF350
ISF350's Avatar
Anyone know any shop can do resurface for the OEM rotors around LA area?
stevelifts
05-25-22 08:25 AM
twixx007
Suspension and Brakes
93
04-26-11 12:03 PM
Rock-a-Lex
15
06-08-09 01:20 PM
PecosBill
14
10-29-08 09:47 PM
DaveJ
10-12-07 01:05 PM
Quick Reply: Front Brake Systems
