Pics of S4play diffusers per request
Perfect!
That's what I was looking for a subtle change to the back end!
What does your backend look like now? You have 2 pics one with it looking like Lou's backend which is black, then the other pic looks like you painted it USB?
The reason I went with the plastic dip was I wasn't sure if I was going to keep it like that for a long time and rather than bring it to a body shop and have them painted or use a rattle can which can be done very easily and it will come out perfect if you take your time and do the proper prep. So I elected to use plastic dip instead because the ease of removal. If I ever got tired of it or wanted to put it back to stock it can be done so relatively easily. If you maintain the plastic tip buy just believe it or not putting wax on it just like you would the body of a car it holds up pretty well and has been on the car like I said for several years. Here are some pics of me prepping the bumper up and spraying it and what it look like afterwards also I'll show you a few pics of the front grill I did that actually took more abuse than the rear from Rock chips to plastic dip. I decided to change up the front which you'll see in the pictures I did this redo during summer.
Makes sense with the plasti dip. Pics look good!
Will probably be looking for a used S4play here soon...
I have this diffuser. The fins are probably too small for real performance usage. The only diffuser that does have real function is the trd oem one. Its quite rare and expensive.
The S4 is a fairly cheap piece of plastic. I ordered one before I had fully researched it and didn't realize that you needed to paint the back end. Ended up sending it back. It provides some aesthetics (no performance as it is just flimsily screwed into the underside of the car) but I decided that I didn't want that piece on my car.
Thx, yea he contacted me and I bought it from him Not bad for $75!
What do you mean you have to paint the back end?
Do you mean the strip above it like what Lou did and Weapon F?
