RR AOS Thumb Screw Replacement
Anyone know the size and where to buy replacement knurled thumb screws that hold the RR AOS? One of mine disappeared and I'd like to grab a couple backups.
edit:
well kind of aggravated now. After couple of trips to home depot, it's not an M8 bolt. It's M5 x 10mm (i got this BOLT.) If u are in a bind or find out in the middle of the night, u can temporarily use a gopro screw but it may be too long. I went past hand tight with the new bolt and will probably use some temp thread locker if it gets loose again.
2011ISFNY (01-09-21)
Yeah I went to Ace trying to find a similar replacement ended up just ordering new ones from RR. I make a habit now of every couple thousand miles checking & re-tightening the AOS & RR tuned intake cover bolts whenever I'm checking oil or cleaning up the car.
Mine came loose once and I ordered a replacment set and now install them with some blue lock tight stuff (dunno how you spell it correctly)...hasn't come loose since.
Returd
Performance & Maintenance
05-27-17 06:23 PM
