Mustang FBO/GT350 intake manifold/E85
E85 shouldn’t give much problems on a car that’s so well engineered. The aftermarket has been using e85 around 10 years. I know I have. I actually used e85 on my old ISF safe cell nitrous kit. I’m pretty sure if a tuner builds an e85 map, that he will interface an ethanol sensor like the rest of the aftermarket to which you will be able to blend pump and ethanol for easy switching. It’s been found that e85 can be corrosive to pre and post filters. Fuel pumps not designed for E85 can fail prematurely since ethanol strips lubrication and attracts moisture. Being able to do a couple tanks of ethanol then gas is helpful because pump gas has a lot of lubrication and detergents. Excessive oil blow by and E85 don’t mix as well. A gum substance will form in the intake runners/valves. E85 det resistance, substantially improves TQ more over HP. So here’s hoping the rods can handle it. Willing to bet e85 TQ gain will be higher in the low rpm than the blower on pump gas.
~Dv8
~Dv8
The GT350 comes with the 5.0 that offers a flat plane crank, similar to those in Ferrari engines. They also come with better flowing heads, nicer interior packages, different exterior trim and better suspension.
The GT350 intake swap can be done for around $1000-1500 where as a GT350 (which is also a low production car) can cost $20k-$30k more then a GT.
I have learned to just buy the fast model from the factory and improve on that.
This same Mustang ran a very impressive time at the drag strip.
I'm looking to run a FBO Mustang S550 (minus E85 and couple minor mods - dynoed at 425WHP) soon. I have a RCF with catback exhaust. Should be a good run.
Thanks for posting this^^^^^^^I follow their channel and was going to update this thread a few days ago but forgot. Anyhow, yea impressive time!
Only issue with the mustang is you will see three dozen of them a day. That would bother the hell out of me having the same damn thing as everyone.
That's freakin crazy, good on ford for finally putting out some decent products. American cars were in such a slump for decades. Even still I think Ford is the only one making competitive products. Don't give two ****s about a Chrysler, dodge, Chevy garbage outside the Vette.
ISFSCOTT
IS F (2008-2014)
153
12-26-18 03:09 PM
