Replacing front map lights and license plate lights -any ISF specific how to videos
Started an LED conversion process today, Rear dome lights were easy. Front door lights were a bit interesting--the bulbs were very finicky and I couldn't put the plastic backing on without the lights either dimming or shutting off. Weird.
I got to the front map lights, removed the two screws from the sunglasses holder and was able to pull the back end of the entire unit down. But, the front wasn't coming off and I wasn't about to put more effort into it, as I can imagine that's an expensive piece if I break it.
I saw the ISX50 videos on you tube, but can't find anything for the F. Anyone have a link or advice on this process?
i was also too much of a wuss to tackle the license plate lights--pulled the trunk liner fasteners off and got to the point where the trunk release pull was blocking me from pulling it down further to access the license plates lights. And with my 5 year old begging me to play football, I gave up since I didn't want to be hasty. Never a free second to get anything done...
Appreciate any help that you can provide for either the map lights or the license plate lights.
Toothy (01-29-17)
I was under the impression that all of the Fs came LEDs in the license plate and map lights?! Maybe it was just the later years...
But also if I'm not mistaken, the isx50 have the same lights (same installation instructions) as the Fs. May want to watch that video and see if it helps you.
V.
V.
Can't help on the license plate bulbs are I didn't do those.
I just attempted the LED interior light conversion over the weekend. I am yet to do the mirror puddle lights as I need more than 15 mins to do them properly.
I didnt take any pics so i will explain the best i can.
The trunk light bulb was replaced first. it is a festoon and i pull down the assembly, took the back cover off. use a small flat head screw driver.
The rear dome lights were easy as. flat head screwdriver with some tape at the ends to prevent scratches and pull the light cover off. Two festoons to be replaced. I noticed that only one of them come on when you get near the car and both come on when you open the door.
The vanity bulbs were next, pull down on the light assembly from the side closest to the door. They come down easy and it is easy to change the bulbs this way. they are T10 wedges. Make sure they are right polarity before jamming them in. proceed to the other side. Again pull down from the side closest to the door.
The front dome was tricky because it was difficult to get the screw head it between the light cover. be careful, you may even use a credit card to avoid scratches. There are 3 wedge bulbs in there.
a piece of advise. get in the car close the doors and wait for the friggin bulbs to cool down. i didnt, used some paper towels and they slipped and got a nasty burn . best to use some gloves for grip. also have small hands.
I have a 2011 ISF BTW. I bought the LEDS from TRS. They are morimoto branded.
hope it helps. This was my second time around as i had changed the lights on my 2IS a few years earlier.
The front map lights I believe are already led. If you're talking about the courtesy lights that turn on when you open the door, or unlock the door with the remote those are halogen and can be removed after popping the cover off. These were a bit stubborn to get out but eventually popped out.
Yes, sorry, I think I used the wrong terminology--it's the lights next to the LED map lights that come on when the door opens that I was talking about.
Kartoos--were you able to get at the front dome lights without taking off the entire sunglass holder assembly? Did you just pull off the two plastic covers and replace the bulbs? It seems like there is not space to stick something in and remove the plastic covers to get at the bulbs. The ISX50 videos I saw showed to take off the entire sunglasses holder unti to get at the bulbs.
I dont know know why my door lights were such a problem. They seemed to be really finicky with their fitment. Sometimes I would get the bulbs in, put the back cover of the light fixture assembly on and something would cause them to dim or even go out??? I ended up leaving them in without the back cover of the light assembly on them--doesn't seeem like this would be an issue, but, I'm not sure how they will behave with repeated shocks from closing the doors.
I had a small plastic tool to help pry the covers off. An old credit card would work too. A small screw driver might work as well, but just be careful as it'll be much easier to break something with the added leverage.
Yep, I stuck the blade of a razor knife in the gap between the lense and the map light console nearest the center of the car (i.e. If you are doing the drivers side map light, it would be on the right side of the lens) and it popped right out.
Now, for the trunk and the puddle lights.
