08 - onwards GS460 LSD Diff into ISF
So, apparently, this is a straight swap, no stuffing around, easy bolt in..?!?!
I spoke to a reputable shop who has done a few. Its almost an identical diff apparently, just for a different car, and its LSD! What the hell?!
Has anyone here done this and can confirm?
They are different part numbers but with the same ratio etc:
http://jp-carparts.com/lexus/part_de...1&part=1093489
http://jp-carparts.com/lexus/part_de...1&part=2273187
Very intrigued..
Very intrigued..
Well that would be the best solution, but i dont track the car, but am fed up with single spinning in the wet.
After a OEM type switch, cheap. The car is worth $40k, maybe, im not dropping close to $4k on the diff for a bit of fun in the wet! But yes, again, i know that the Giken is fantastic, just cant justify it.
lobuxracer, you definitely had some seat time for the Os giken tcd. Is it a direct fit into our 08 differential? Also, how big of an improvement is it compared to the torsen lsd from 2010 and up?
I am ready to trash the Torsen in my Supra because the Giken is so much better. Seriously.
You'll find plenty of first-hand feedback on this thread. One of our CL members, Ken Henderson, recently swapped out his Torsen LSD from his 2010 IS-F to an OS Giken TCD and his initial impressions can be found on post #38.
BTW, it's fun reading how much of an OS Giken advocate lobuxracer has become since he installed his TCD unit on his IS-F. There's no going back to lesser differentials once you've experienced what the OS Giken TCD is capable of!
Can anyone confirm if the 2013-2016 LS460 rear carrier contains a torsen diff or an open diff?
EDIT: looks like the sport package contains a torsen diff and the base model does not. So from what I understand, the OEM carriers that contain a torsen diff that may bolt in would be:
10+ IS-F
13+ LS460 with sport package
15+ RCF w/o TVD
10+ IS-F
15+ RCF w/o TVD
10+ IS-F
15+ RCF w/o TVD
10+ IS-F
15+ RCF w/o TVD
