Only driver side door locks and unlocks
I just realized that only my driver side door is locking and unlocking both with the key fob and the power door switches. When I hit the lock/unlock button on the door switch it sounds like it is trying to do something on both the driver and passenger side so I am thinking probably actuator.
My question is will the front passenger side door lock actuator keep the rear doors from locking and unlocking as well? Or do I possibly have 3 bad door lock actuators? Thanks
might be a simple fix with techstream i think there's a safety feature to only unlock only the drivers door that you can enable or disable in there. but very well could be the door actuators.
Didn't have tint done recently unless it was removed before I purchased the vehicle. I've only had the vehicle 2 weeks. I tried to look for fuses but all I saw looked like one large fuse panel that didn't let you change individual fuses
It sounds like the same problem I had with my isf. In my case both drivers side doors did not work . So here is what I did :
I took the actuators out of the doors , opened up black plastic casing to get to the actual electric motor . Pulled the little motor out and did a bench test with 9v battery ( same battery that is used in home smoke/ fire detector/ alarm ). At first, the motor did not move at all. I sprayed WD-40 inside of the motor and let it sit for few minutes. In my case, the center shaft was frozen but after wd-40 treatment it loosened up and the little motor started to work with the 9v battery. I used compressed air to clean out the excess of wd-40 from inside of the motor. I put everything back together and the problem was gone. Both doors are locking and unlocking as they are supposes to. It has been 5 months since the repair was done and 0 problems so far.
I can press it 50 times. Only the drivers door will unlock. Does techstream really have an option to never let the other 3 doors unlock? Seems very silly if it does.
As I mentioned, my driver's side front and driver's side rear was not working and my passenger front and rear was working just fine. And for time wise, it took me aroud 3 hours between both doors. If you decide to do it , just take your time taking actuators a part , there are some small parts ( gears ... ) in the enclosures..
ZeekGS300
04-20-07 07:36 AM
