SmartTap Relay Installed
Sub'd for future updates
Your #1 Lexus Vendor
Direct from my guy over at Diode Dyanmics..
"It's possible he received one from our first production run, which we are still trying to replace for anyone who was affected.
Basically, our production team was using the wrong-spec capacitor, which would cause the module to fail under the load of incandescent bulbs. We've since corrected the issue and had no failures yet.
Direct him to us for a hassle-free replacement.
It's also important to add that these are manufactured in the USA, and our product has more functionality than the TapTurn, while being offered at a significantly lower price. It's also a complete replacement, digital flasher vs. a modified original CF18."
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
JPxMODz (03-20-17)
Former Sponsor
^^^ We did, but there were still some already in the hands of distributors, etc. We did our best to swap and pull initial once, but there was a few hundred already out on the market.
I'm sorry for the trouble. The issue in the first run of the modules specifically affects high-load situations. Since you have 6 bulbs total blinking, you're basically at the "max" load potential scenario. They are now completely tested and functioning with 6 total bulbs, no problem. You'll be up and running again in no time. I'm sorry for the trouble! Otherwise, looks great, thanks for posting the video!
Meraki Autoworks or JPxMODz, please reach out directly here or contact@diodedynamics.com if you need assistance with replacement - seems Meraki is already in touch, but just let me know if I can be of any help in getting a new unit to you. Thanks!
Former Sponsor
We contacted customers who received units from the first production run and have worked hard to make sure everyone receives replacements.
My apologies for the inconvenience, but we stand behind our products with a 3-year limited warranty and we will make sure you are taken care of.
Thank you,
Nick C.
There is another type of this relay here:
https://www.amazon.com/gp/product/B00CP20HLS/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
I had the same problems as JPxMODz.
http://www.nigel-jdmparts.com/index....roduct_id=2342
Lou
We just installed that on our WRX!
Going on the F next..
Contact us for this part guys. Only $60!!!
-Josh
https://www.youtube.com/watch?v=BkzcEJuHEEI
-Josh
Just a note for those looking to buy this. After a full day of testing the SmartTap, my relay appears to be DOA. I had no signal indicators or hazards working when I went out to car today. I unplugged the relay for a minute, plugged it back in with no positive results. Plugged the stock relay back in and everything is back to normal and fully functioning. I have since emailed support at Diode Dynamics for a replacement. Hopefully the one I have was just a dud. I'll update the thread accordingly. On a side note, I have never seen a defective relay...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Our very own CL sponsor Nigel-JDMParts has this same relay for $39.99:
Lou
Lou
We have try a few lexus model and it works perfectly fine.
Group buy could be done if there is interest.
JPxMODz (03-21-17)
So this is all this relay does here that Nigel-JDMparts sells?
^^^Yeah that's what I thought. I'll stick with the SmartTap for the extra features. But if all you want is the tap feature, then this is a good option
Taken from Diode Dynamics product page...
The SmartTap™ is a replacement turn signal flasher module compatible with any vehicle using a CF18 (LM449) Flasher. Programming each mode is simple with the help of the included programming guide and the use of existing vehicle controls.
Tap-to-Signal: One-touch signaling is a convenient way to signal to other drivers when switching lanes. Simply tap the turn signal for a series of signal blinks.
Arrival and Departure Modes: When the lock or unlock button is pressed, the surrounding area will illuminate for better visibility when approaching or leaving the vehicle at night. The lighting time can be adjusted from 10-90 seconds for additional illumination, or disabled if desired.
Unique Hazard Functions: The SmartTap™ has built-in strobe, slo-mo and wig-wag hazard functions to help the vehicle stand out when the hazards are on. Apply these functions on their own, together or with the strobe setting for a total of EIGHT unique hazard functions!
The following 2 users liked this post by JPxMODz:
5280ISF (04-30-17),
MileHIFcar (03-21-17)
