SmartTap Relay Installed
#46
Installed the SmartTap last nite. It's working as it should
BTW, no matter what anyone tells you, installation is NOT easy. You have to remove the bottom panel of the dash no biggie. Then finding the the relay - I used this:
https://www.clublexus.com/forums/is-...y-located.html
Also no a biggie - BUT getting the darn thing out and the new on in is a PITA. I have small hands, and you can only fit one hand in the small space.
Lou
Lou
Simply unplug the harness from the stock relay, then plug the harness into the SmartTap relay. Tuck the relay back under panel and your done! If your concerned about the relay flopping around, secure it with a wire tie. Leave the stock relay alone. I've done this to my last three cars. Not sure why anyone would go through all that painfull effort to remove the stock relay
I'll admit it is a tight location and a bit of a pain to access, all the more reason to install using my method
#47
Lou
Lou
#48
Installation is super easy and takes less than a minute if you the job my way ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
I'll admit it is a tight location and a bit of a pain to acces, all the more reason to install using my method![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Lou
#54
I just installed the SmartTap in my 2014 IS F this evening. Installation went fine. You do need to contort yourself upside down and really crawl under the dashboard to get the job done. I also pulled the lower dashboard cover (2 screws) for better access, and used a really good flashlight.
All functions work so far except the unlock lights on for 20-sec (arrival) delay. The lock function w/20-sec (departure) delay works, one touch 4-blink works, and the variety of hazard light patterns work. I was mostly after the one touch 4-blink feature. First day only, will post/comment if something goes south.
Do make sure you pull the right relay. On my 2014 the OEM relay was light tan (P/N 81980-30170). There was a similar looking relay further up the dashboard that was green. That one is evidently for your stop lights... don't pull that one (it is also keyed differently). Lou's post (#43) on the prior page with the link does show the correct relay location and mounting point, just don't assume your OEM relay is the same color.
Regards,
- Kirk
Regards,
- Kirk
#55
Regards,
- Kirk
Regards,
- Kirk
The unlock 20-sec arrival works fine. It won't work using keyfob. You have to push the unlock button on outer door handle for it to work. Just the lock 20-sec delay works fine from the keyfob
JPxMODz (03-30-17)
#59
Recieved my replacement SmartTap. Everything including ALL features are functioning correctly. I'll report back in a few days if things are good to go.
- Kirk
