SmartTap Relay Installed
#76
Nice video, how did you change your front turn signals? did you do it with the bumper off? because I couldn't squeeze my hands to change mine with the bumper on and I have small hands.
#77
Thanks Josh!
I must have smaller hands and a small forearm then haha. I pretty much made my hand as long and as skinny as possible, got up under the headlight and felt the tab, twisted and pulled the bulb out - all with one hand. Then had to take time and put the bulb on the socket by means of opposing pressure (finding something to push the socket against) and clicking the bulb in, then putting the socket back in the headlight. It requires some patience and is by no means easy, but is doable. The driver side I had to unbolt the washer fluid neck to get easier access.
#78
For anyone annoyed by the lack of the arrival feature working on the CF18. Diode Dynamics has created a list and is working on resolving the issue. Contact their support team and they will add you to the list. Once they identify the issue, replacement units will be sent out
#79
^ I have received mine but haven't had time to do the install.
What exactly does the arrival feature do if you don't mind me asking?
#80
Watch the 2nd video on the first page of this thread with the Subaru. It demos the arrival function at about the 2:15 mark of the video. It keeps the parking lights on for a specified time (I think it was 20 seconds?) after unlocking the doors with the remote.
#81
^ Thanks buddy, makes sense now.
#82
I'm going to try to install this soon to see if I get the same issue with arrival. Spoke with Diode Dynamics tech support, and they mentioned to me it's only happening to a small variety of users.
#84
Everything else works as advertised including the departure feature. I still love my Smart Tap... perhaps it's because I have a 2014 IS F?
- Kirk200
#85
My arrival feature still doesn't work - tried the key fobs and the door itself. I also have an F keycard as well (no buttons).
- Kirk200
- Kirk200
#86
For who have installed this... Was your relay green and located pretty much in the centre? Any tips on removing the stock relay completely out of it's bracket? Yes, I could just remove the stock harness, and plug in the SmartTap, but I want to do it right.
#87
Can't remember, but I think your correct on the relay being green and in the center. I didn't pay to much attention as all I wanted was the harness
#89
Now, I also do not have correct operation of the arrival light using either the fob or the door handle to unlock. I suspect it has something to do with the double-blink of the signal lights interfering with the hold-time, but I didn't design the thing. Everything else works perfectly. I finally have the tap to lane-change feature of my wife's RX. Love this car.
Diode Dynamics (05-22-17)
