TPMS sensor and which tire??
Is there a way to figure WHICH tire has low pressure when I get a low tire pressure warning? Low profile tires are not easy to tell from glancing. Is there a device I can buy that can give me the individual reading?
Tech Info Resource
Or get a later model Lexus. The RC F and GS F show the numbers on the dash. Wish the IS F did too.
An easy way is also to buy these. Visual indicators of which one is low.
http://www.ebay.com/itm/4-Pcs-Car-Au...RYTt3j&vxp=mtr
Notice - the material is chromed metal. Would be a problem with the aluminum stems on the ISF. See this thread:
https://www.clublexus.com/forums/is-...alve-caps.html
And my post from seven years ago:
Lou
I had heard from my local Discount Tire store the last time I put tires on my wife's car, that there is an issue with dissimilar metals with the TPMS valve stems. The stems are aluminum and if you use chrome steel caps, like I wanted to use, there can be an issue with dissimilar metals that causes the valve cap to attach itself to the aluminum TPMS stem. Polished aluminum caps are OK, as are plastic. The dissimilar metals issue apparently happened to the OP.
