2008 ISF won't unlock
My car won't unlock via the controller button. It will if I grab the handle. It locks and the trunk will open using that remote. I've used both remotes and switched batteries several times.
Any help would be great.
I remember reading something similar in a IS250 forum. End of the day its a remote issue, not an ISF issue so this might help.
It was something along the lines of having the remotes on you, then push/hold start until you hear 3 beeps. The beep intervals might be several seconds between but once you hear all 3, its calibrated the remotes or something to that effect. I recall the OP saying initially he thought it didnt work but when he tried an hour later it did so wether this means there is some kind of delay, im not sure.
Good luck
Good luck
Good luck
Good luck
rosegold
10-13-13 06:45 PM
