Which are the best Coil Overs for the ISF?
Agreed. Best is relative to the driver. Some are more budget-conscious, while others want the most performance oriented coilovers on the market.
But without knowing too much, BC Racing with Swift Spring upgrade is a good coilover setup for street and track driving. Going deeper in the wallet, KWV3, Penske, and Ohlins provide great road feedback and they're engineered for the track. And from what I recently saw over the weekend, RR Racing will have a new coilover offering, so you might want to look at that as well.
It really just depends on your budget and desire for the F.
Best of luck!
Best of luck!
Thank you for the information.
Budget is open. I am not going to track the car, and have several other sports cars with Coil Overs (All from LG Motorsports). They are not adjustable and are full race set-ups with associated sway bars and the like.
That being said, my ISF will just be driven on the street. Thus, I like a stiffer ride and want the best set-up for the ISF (As I am not sure what is out there).
Thanks for all of the help.
Joel,
Just let me know which route you end up going..
-Josh
-Josh
__________________
![](https://www.clublexus.com/forums/signaturepics/sigpic167102_16.gif)
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Hi from over the pond.
I was in a similar situation to you, I have a 08 ISF only used on street and was looking at upgrading the stock suspension. I went with the BC racing option 14/10 as I am on standard rims and not looking to change them. Rear height is set to stock ride height and the front is 0.5" lower than stock. Dampers are set 17 click out from full stiff front 22 clicks out rear.
Now I have had them on the car for 4 months and here is my assessment:In terms of turn in, and body control there is a significant change for the good over the stock items (I’m also running RR USRS’s).The car is also more balancing when braking heavily and the lean forward has been reduced significantly. Comfort wise is where I am not entirely satisfied, even on the softer settings pitted roads are felt through the car however the main issue for me is how the suspension reacts to a series of undulations in quick succession on the motorway (freeway) at speeds of 70mph+. I find myself almost lifting out of my seat in this situation. These are not sharp bumps but rather a quick series of dips and crests taken at speed, the suspension simply does not cope with this well.I have spoken to a few tuners here who work predominantly on German cars like M3s, M5s, AMGs etc (Lexus Tuners are few between here) and they all came back with the same response, you’re running a far too aggressive spring rate for a daily driven car and the shocks can’t control the spring in situations outlined above. They suggested swapping out the springs for a much milder spring rate, as comparison one gentleman I spoke to who owned an e39 M5 ran 8k/6k, however I would have to send the shocks back to BC to be re-valved for the softer springs.Now reading on the various threads, most guys are running even more aggressive spring rates than 14/10, but I believe most people are lowered over stock significantly and obviously the road conditions are different in the US to here in the UK but I believe for what I was looking to achieve I should have gone with something less aggressive. I’m not disappointed though as for the price point the improvement over stock is worth it.I’m going to run with these and may look to swap out some time this year with either the KW V3s which from reading around use a softer spring rate and will be more suited to UK/European roads. Or I may look to see if I can find 2012+ OE setup or go with the Bilstein B6 dampers with OE or mild progressive lowering springs (Eibach or Tein H techs).As a side note I have not yet explored the more aggressive damper settings yet, I’m not sure that will cure the problem mentioned above but maybe it will? Open to opinions on this….my current settings are the stiffest I have tried so far.
