Finally Installed OEM Rear Fog Lights
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Finally, I’ve managed to install OEM rear fog lights on my GCC Spec ISF.
Parts needed are as follows:
New indicator Stalk which include the additional selection for the rear fog light: 84140-30311
New Rear Inner Light clusters which include the rear fogs:
81580-53071 Lamp Assy, Rear, RH
81590-53071 Lamp Asse, Rear, LH
Changing the indicator Stalk was pretty straight forward after watching one or two videos on YouTube, and changing the rear Lamp was even easier. Pics below for reference of the change but it was a simple plug a play.
The only thing I’m trying to sort out now is displaying the rear fog lights on my dash when they’re switched on.
The light for the rear fogs is in the dash but I think it needs to be programmed by the dealer or something.
I’ve looked into Techstream but can’t find anything to help activate this light.
Enjoy the pics
Old Vs New Indicator Stalk:
![Name: F4DADE97-1BB4-4E9E-B60A-E8A18367BBAE_zpsachevl9x.jpg
Size: 117.9 KB](https://www.clublexus.com/forums/attachments/is-f-2008-2014/414705d1501201578-finally-installed-oem-rear-fog-lights-f4dade97-1bb4-4e9e-b60a-e8a18367bbae_zpsachevl9x.jpg)
Bottom Lights are the new ones with the fogs installed:
![Name: DF0DBA47-9792-45E6-9D67-C5BBAAEE4C19_zpsuggyumul.jpg
Size: 128.8 KB](https://www.clublexus.com/forums/attachments/is-f-2008-2014/414706d1501201578-finally-installed-oem-rear-fog-lights-df0dba47-9792-45e6-9d67-c5bbaaee4c19_zpsuggyumul.jpg)
![Name: NFG1_zps7deufujh.jpg
Size: 113.2 KB](https://www.clublexus.com/forums/attachments/is-f-2008-2014/414707d1501201578-finally-installed-oem-rear-fog-lights-nfg1_zps7deufujh.jpg)
Enjoy the pics
![Name: FOGS1_zpsppf708ni.jpg
Size: 82.9 KB](https://www.clublexus.com/forums/attachments/is-f-2008-2014/414708d1501201578-finally-installed-oem-rear-fog-lights-fogs1_zpsppf708ni.jpg)
21ce (03-27-21)
This is a very nice mod.
I see on the new stalk where you can select the between the 2 different fogs (front and rear), unless I'm missing something from the picture, how do you go about having them on at the same time?
*Also if nothing is wrong with the old on, would you be willing to sell it. Pm me regarding that
I don't plan on using my old indicator stalk but shipping alone will probably make it more expensive for you and it'll probably be cheaper to buy it from Ebay or the dealers as I'm half way across the world
Can't remember what he wired it to and how it switched on and off.
Can you explain what you mean by using a relay system to activate the lights when the fogs are on?
You can do it that way but you need to cutout the circle for the lights and connecter pretty perfectly
The only problem I'm having is showing up the fog light display on the dash
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Awesome mod, specially for our winter driving. I just checked and can confirm that my Canadian '12 ISF has the same space for the rear fog lights as OP. Question OP: did you have to add that red/black wire for that extra bulb? When I check the connector there are only 3 prongs in that 4 prong connector. You said harness for the rear fogs is there in your model which to me means no modification (splicing) to original harness needed, only unwrapping of the black oem electrical tape.
