Stoptech brake pads may cause vibration ?
running the stoptech f/r pad setup without changing to new rotors. broken in per instructions and I have 0 vibration. I would second those who have mentioned improper pad transfer .
ISF350 (05-17-17)
Do a google search for "Pad Imprinting". That's probably what you have.
Steve
Steve
Former Sponsor
If you already have pad deposits or a pad imprint causing judder then going to bed or re-bed is not likely to make anything better. You're going to have to drive the car normally for a while to scrape away the excess pad material and then you can try to re-bed the brakes.
-Matt M.
smokyis350
Suspension and Brakes
03-16-10 03:51 AM
