How Much Power Does AC Consume? Dyno AC vs No AC
ap2s2k (06-06-17)
Just read about a system that uses the A/C to cool the inlet temperature as a extra capable intercooler!
Apexsports (06-06-17)
Good to know. Always wandered about this myself and read many posts but hard to seperate fact from fiction. Good to see before and afters to confirm it.
Problem is like he mentioned, as our cars have decent HP, its easy to forget to turn it off for a quick blast from the lights etc as its still quick :-)
Pity it didnt have a cut out like some cars on WOT to disregard forgetting to do it manually.
Tech Info Resource
The following 3 users liked this post by lobuxracer:
The way the unit in all the 2IS works isn't like the old school A/C units. It's a variable displacement compressor, so it actually modulates the amount of power it uses based on thermal load as calculated by the A/C ECU. Sure, turning it off guarantees minimal load, but this system is nothing like the old school systems, and it definitely is smart enough to minimize the load at WOT. Even the Supra, as old as it is, turns off the compressor at WOT automatically, but it has the old school clutch system where ours have no clutch.
Tech Info Resource
I got my *** handed to me in the 2IS forums early on because I didn't do my homework about the air conditioning system. Much like the folks who've never seen electric power assisted steering and post about power steering noises in the 2IS, I assumed the 2IS had a conventional compressor and clutch setup, and someone posted about the variable displacement compressors. Needless to say, I felt pretty dumb, so I learned about them. I already understood systems designed to move heat from one place to another from my work in cryogenic gas separation and high vacuum systems, so it was just an adjustment.
