Transmission issue surge/thumping sound
wondering if anyone has this similar issue. From 2nd - 3rd in manual mode with partial throttle I have a surge as in it takes a second to shift to 3rd and It isn't as smooth as a shift compared to the other gears. At WOT no issues, but that one gear change has a slight hesitation and if I let off in 3rd I get a loud thump before it actually shifts with partial throttle. In auto it's smooth and no issues. Just had a transmission flush about 8000km ago. Wondering if I should call the dealership back because this wasn't happening before, I do downshift a lot to hear the exhaust rev match but before I take it back just wanted to see if anyone else has had this issue. Thanks.
Tech Info Resource
Sounds like you should check the level first. It is well known to be a primary cause of anomalous behavior in these gearboxes. Just because they "flushed" it doesn't mean they set the level correctly.
They did mine and I still have the minor flare in 4th every morning if I'm going down hill. They rechecked and added .3 qts and it's the same .
I don't care anymore lol. I drive the shot out of mine and she's fine. A slight flare only in the morning in minor. For what you are describing I'd take it back
4TehNguyen
11-02-14 07:41 AM
