Rear Camber Kit and toe links
Hey guys,
I recently lowered my F, and due to tire wear I am planning to upgrade my rear camber kit and toe links. I'll do it one at a time and will do the front in the near future. Any suggestions is highly appreciated.
I am looking into two different product/vendors such FIG Engineering and MEGAN racing. Also, I would appreciate if anyone from this forum who can provide any coupon code that i can use for the discount.
Thanks again.
Don
Thanks again.
Don
lmac33 (06-19-17)
Hey guys,
Thanks again.
Don
Thanks again.
Don
https://www.clublexus.com/forums/2ge...omponents.html
ap2s2k (06-21-17)
2. FIGS will stand behind their product and offer replacement parts should you need them. Megan, not so much.
3. Using FIGS rear Mega Arms rather than Megan camber arms will reduce the magnitude of the dynamic alignment changes and reduce tire wear.
Learn from my experience. On the rear I put both sets of Megan upper control arms and toe arms. Ended up destroying a ball joint and Megan will not sell replacement ball joints. Because I was dumb enough to replace both upper control arms my dynamic alignment (toe in particular) was off, wore out a set of tires in ~5,000 miles (that was my fault, not Megan's, but statement 3 still applies). After 2 years my rear toe arms are seized and won't adjust any more.
On the front end I have a set of Megan adjustable UCAs, which I am relatively happy with, but I am in the process of replacing everything on the back end with stuff from FIGS.
@JDVM8 - If I choose Megan instead of FIGS maybe because of the price. But I need something durable and recommended by Club Lexus.
@Isfast - I will check your list and will send you message in case i am interested with the parts.
@WylieKylie - I am really gearing towards FIGS, however I cannot reached the FIGS customer support, I am always routed to voice message. I left a voice message and no one have return my call. I am scared if I place an order it will take some time for the parts,
Thanks for your reply. Is there a faster way to contact FIGS?
A little camber will not hurt the tires. Make sure to correct your TOE alignment, as this affects your tires more than anything.
I've ordered a couple of things from FIGS before and the wait time was never an issue for me. Just keep in mind that these are custom made parts, you might have to wait a week or two while your order is built.
Not necessarily. The rear end has adjustment through eccentric bolts, the front tie rod ends are adjustable as on all cars. The eccentric bolts on the rear end are ok, but a bit of a PITA for fine adjustments. I'm a bit of an alignment ****, so I replaced the rear toe links to make adjustments easier, and to tame the aggressive toe curve as much as possible. As mentioned elsewhere in the thread you need to replace the front, lower, rear bushings with parts from FIGS or RR Racing to fix the inner wear on the front tires.
jnguyen87
12
05-30-11 03:06 PM
