Love my ISF on track , but picked up a new track car
Love my ISF on track but not really enough power for me, I have been looking for a a car that would give me at least a semblance of what my single turbo /wide body Supra could do . Settled on the 2017- ZLI only a couple of hundred miles on her but seems like its gonna be a beast on track 650hp/650tq 6 speed , magnetic suspension. big brakes and lots of coolers 11 in all . The ISF will continue duty as my wife's daily driver .
I included a stock photo of the car on track
POWER!! Very nice car.
-Josh
-Josh
__________________
![](https://www.clublexus.com/forums/signaturepics/sigpic167102_16.gif)
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
All the Facts: 2017 Camaro ZL1
Build and Price available at: http://www.chevrolet.com/camaro-zl1.html
Engine:
Chevy Small Block LT4 6.2L/376cu in V8
Direct-Injection, Variable Valve Timing
650 hp @ 6400 rpm
650 lb-ft @ 3600 rpm
redline: 6600 rpm
**new for 2017 includes an integrated PCV oil vapor separator, taller supercharger plenum cover for larger intercooler bricks and improved IAT cooling.
More details: GM Media Release - LT4 V8
Performance/Figures
Coupe:
0-60 (manual)...............3.7 seconds
0-60 (auto)...................3.5 seconds
1/4 mile (manual)..........11.8 seconds
1/4 mile (auto)..............11.4 seconds
Lateral acceleration........1.02 g
Convertible:
0-60 (manual)...............3.9 seconds
0-60 (auto)...................3.7 seconds
1/4 mile (manual)..........12.0 seconds
1/4 mile (auto)..............11.6 seconds
Lateral acceleration........1.00 g
Braking Distance............107ft/110ft (coupe/convertible)
MPG (city/hwy).............................12/20 (auto)
.................................................. 14/20 (manual)
Track Times
Nurburgring: 7.29.60
Big Willow: 1.26.16
MT Figure Eight: 23.1
Dimensions (+/- vs LT & SS)
Width............................75" (+.3")
Length...........................190.2" (+ 1.9")
Height............................52.9" (-.2")
Front Track Width.............63.4" (+.3")
Rear Track Width..............62.0" (-1.1")
Wheelbase.......................110.7" (+0)
Wheel Offset (F/R)............20mm / 43mm
Weight (lbs)...................3883 (manual coupe)
....................................3944 (auto coupe)
....................................4113 (manual convertible)
....................................4148 (auto convertible)
Equipment, Options, and Details
Fun Facts
Major Component Origin:
Owners Manual: HP ZL1/1LE Supplement - 2017 ZL1&1LE Performance Supplement.pdf
2017 Camaro Vehicle Catalogue - 2017-chevrolet-camaro-catalog.pdf
Engine:
650 hp @ 6400 rpm
redline: 6600 rpm
Performance/Figures
Coupe:
Convertible:
Track Times
Big Willow: 1.26.16
- Manual Transmission - Tremec TR-6060 6-spd (MJK)
- Automatic Trans - 10R90 10-spd automatic PERFECT 10 article, HOLY SHIFT article
Gear Ratios...............M6.............A10
1.............................2.29...........4.70
2.............................1.61...........2.99
3.............................1.21...........2.15
4.............................1.00...........1.80
5.............................0.82...........1.52
6.............................0.54...........1.28
7..............................................1.0 0
8..............................................0.8 5
9..............................................0.6 9
10.............................................0.6 4
Final.........................3.73...........2.85
- Electronic Limited Slip Differential (eLSD), clutch-type with hydraulic actuation. Varies between full-lock, and full-open at the computer's command...NO BRAKE INTERVENTION
- Gen III Magnetic Ride Control Dampers: dual coil, magnetorheological fluid, "reads" the road and reacts every inch of travel at 60mph, or every 1/1000 second.
- Forged 20x10" (Fr), 20x11" (Rr) Wheels
- Goodyear Eagle F1 Supercar 3 tires: 285/30ZR20 (Fr), 305/30ZR20
- Performance Traction Management Software, Wet, Dry, Sport 1, Sport 2, Race
- Custom Launch Control, No-Lift Shift, Burnout Mode, and Active Rev Match (manual-only)
- Carbon Fiber extractor-style hood vent
- Full-optioned interior similar to 2SS, with black suede & leather panels, and red stitching accents.
- Power Recaro seats w/ suede seating surfaces & heat/cooled
Fun Facts
- The 2017 ZL1 has slightly smaller frontal area than the 2015 ZL1
- All body shapes, including "overlooked" items like the bumper cover were extensively tested and formed in the wind-tunnel
- Goodyear Eagle F1 Supercar 3 tires mark the first application of Goodyear's new design...developed specifically for ZL1 and 1LE.
- Designers and Engineers trimmed the thickness of the front grill during wind-tunnel testing in order to reduce turbulence and increase airflow to the heat exchanges.
- Red seatbelts are included with the following colors: White, Silver, Red Hot, Nightfall Gray, Black, and Mosaic Black. All other colors get black seat belts.
- Al Oppenheiser remarked that the new ZL1 achieved levels of speed on the Nurburgring that necessitated using driving lines on track similar to open-wheel racers.
- The A10 features several "easter eggs". For example, when driving in a highway gear, you can hold the downshift paddle for one second and the transmission will immediately shift into the lowest possible gear for a pass.
- The manual transmission ratios allows the car to accelerate to 60 mph in first gear.
- The A10 programming, in "D" includes three different levels of shift calibrations, depending on how hard the driver is pushing the car.
- All Camaros are assembled in Lansing, MI @ GM Lansing Grand River Assembly (or "LGR")
- LT4 engines are built at the GM Tonawanda, NY powertrain plant. No ZL1 engines are built in Bowling Green, KY.
- A10 transmissions are built at the GM Romulus, MI Powertrain plant.
- All M6 transmissions are built in Queretaro, Mexico by Tremec (whose worldwide headquarters are located in Mexico City, Mexico.)
The following 2 users liked this post by suprasupra:
2URGSE (06-22-17),
RJMacReady (06-18-24)
You could absolutely DD this car the recaro seats are super comfortable and the magnetic suspension in tour mode is supple /combined with stealth mode exhaust quiet and smooth I would opt for the 10 speed auto if I was going to DD this car it actually is quicker than the manual but not as engaging to me
I would say way better all alcantara dash,doors,seats, ect . I don't think there is a better bang for the buck car out there right now with so many things it can do well
Good choice sir, I think you will find this beast to be very deadly on the track (not sure about twisty tracks).
Also, your Supra is glorious...one of the classic 90's cars I must have in my collection before I turn 40.
very nice pickup for the track!!! Love the white!!!
Yep the visibility is limited but the gen 6 is way better than the gen 5 cars. I'm already used to it 6'3" and no problems
MisterSkiz (06-19-17)
