RC-F rear rotors on the IS-F - Pictures and DIY
Hey guys!
DIY Tutorial with pictures will follow the next days, please find attached some pictures of the rotors and pads in comparison.
Lexus RC-F rear rotors on the IS-F
Plug & Play, can be only used together with IS-F brake pads, the RC-F ones are a little bit longer, so they won't fit into the OEM calipers.
Unfortunately it's not possible to use the rear RC-F calipers on the IS-F because the distance between the brake bracket is 5mm too long on the RC-F calipers 🤧
Pad comparison
Both pads fit on the rotor
Ventilation
Brake pads
Left side RCF
Right side ISF
Pad comparison
Ventilation
Brake pads
Left side RCF
Right side ISF
Presumably as owners of RCF's start changing out their cars and fitting aftermarket parts, you could see a few sets of lightly worn RCF OEM rotors up for sale via the forum/eBay etc.
If so, could be a cheaper way of upgrading from the drilled to the slotted type of rotor now seen on all RCF's, GSF's etc.
Op has already mentioned why you can't use the RCF calipers or pads.
Thanks for posting this, OP! Curious about the weight difference between the two... Please let us know if you can weight them.
Thanks for posting this! I have the RR Racing front rotors, which are slotted, so I've been meaning to source this info to see if I can replace my rear rotors with the slotted RC-F rear rotors, and now i know!
-R
-R
^^^^IMHO the ISF front caliper is a better choice because there is a better pad choice. They are supported by more third party pad manufacturers - Ferodo, Project MU, Hawk, StopTech and etc. The OEM Brembo front calipers in addition to Lexus, are used by MB and other performance manufacturers.
Lou
Lou
lobuxracer (10-01-24)
scorpionge
19
11-07-14 10:00 PM
TOMMYPHAM
12
11-08-13 02:40 PM
mikellucci
04-17-13 01:12 PM
mikellucci
18
02-14-13 05:27 PM
