Enkei RPF1 18s on ISF
#31
have you found any fixes for running into the reservoir on the KWs? i have them on mine as well and im trying to throw some apex ec7 18x10 +43 and im running into the same issues!
#32
I grabbed some eibach 15mm spacers - 265 35/18 Tires - raised the KW's all the way up on all corners. The only rubbing is tire on fender liner in an aggressive corner, I primarily track the car.
#34
10mm may not be enough. I needed 11mm of clearance that I on a 18x10 - 38et wheel. I do recommend you measure on full lock to be sure a 10mm will work. Be sure to get extended lugs! And, no fender work.
#35
i bought the H&R extended stud mount spacers so hopefully those work, but ill be taking it to a shop nearby to have it installed with some other parts as well. When they were last put on to test i could only get about 3/4 of a turn or close to that, and the shop said a 8-10mm should work. but thanks for the info!
Dattaboi (12-10-22)
