Recommendations for shops in Atlanta to get coilovers adjusted
Old 08-28-17, 07:56 AM
reggiereg
reggiereg's Avatar
Default Recommendations for shops in Atlanta to get coilovers adjusted
My tire is scrubbing at high speeds (especially corners) on the front passenger side. I believe my coilover needs to be adjusted but not sure. I do need a high-speed balancing as well.
Are there any shops in the Atlanta area (preferably Decatur) that can do this type of work?
Old 08-28-17, 08:04 AM
Vervish
Vervish's Avatar
if all you need to do is raise it a little (without corner balance), it is a super easy DIY. Just remove the wheel..and spin a coilover nut.
Old 08-28-17, 08:13 AM
Richy21
Richy21's Avatar
Could be a few things. Any thumping or unusual noises? Stick you hand and see if the fender liner is ripped
Old 08-28-17, 02:00 PM
tas02
tas02's Avatar
If you've never had your coilover equipped car professionally lowered/aligned/corner balanced (done all at once), do it. To get the benefit of parts you paid extra for just for their adjustability.
Old 08-28-17, 06:23 PM
eaglclon12
eaglclon12's Avatar
Grand tourismo in Chamblee. They are pricey but these guys are good when I comes to alignment and suspension adjustments. Had my 1990 Skyline GTR done there.
Old 08-28-17, 08:12 PM
Rickna
Rickna's Avatar
If you're going to DIY, as Vervish said it's quite easy. However you should measure it with a calipers or at least a tape measure if you want the car to sit squarely.
BocaVdub
Suspension and Brakes
08-26-15 06:36 AM
aTeAse
04-15-14 05:59 AM
mcme
IS F (2008-2014)
11-28-13 01:24 AM
k_kush
Chicago Lexus Club
19
12-04-10 01:18 PM
smokyis350
05-03-08 11:04 AM
Quick Reply: Recommendations for shops in Atlanta to get coilovers adjusted
