Iphone not connecting to Bluetooth Audio
My Iphone 7 connects fine to the Bluetooth for phone calls through the speakers but when I try to connect to Bluetooth Audio to listen to my podcasts it fails to connect and says to check my device for problems. It's weird because my Iphone 6s connect fine and now the Iphone 7 won't connect whatever I do. Anyone run into this issue?
I could be wrong here, but I had the same issues with my Galaxy S8+ and Note 8. No problems pairing for phone calls, but no go on BT audio for music. My Galaxy S7 Edge and S6 Edge no problems at all for both phone calls or BT audio. I believe your iPhone like my newer galaxy devices has the latest bluetooth standards and do not appear to be backwards compatible with ther older bluetooth version on our IS-F
Must be an issue with my device.
I went to http://www.lexus.com/mobilelink/ and checked to see if my car is compatible with my device for Bluetooth Audio and it says it is.
further clarification: they are paired separately for some reason, hence the two setups
I managed to get all my newer Galaxy devices to connect to BT audio. You have to register BT audio seperately after you register call audio. I had two other previous devices registered in BT audio also, so I removed one and I was able to connect
murfman89
12-16-16 06:43 PM
bdar
ES - 5th Gen (2007-2012)
11-05-10 10:32 AM
