Transmission in auto mode
Curious if anyone else encounters this......
I could be driving on a nice straight bit of road (auto mode), doing about 80km/hr and decide to floor it (hard acceleration). The transmission will kick down from 8th to about 5-6th gear and then a second or so later kick down again to 3-4th gear. More so in normal auto mode but sometimes even in sport+ mode. Its like it accelerates in 2 stages.
This generally happens on the first hard acceleration when i drive the car. If i do the same thing moments later, it will kick down from 8th to about 3rd gear.
Of course in Manual / paddle mode this doesnt exist but if i need to accelerate hard from 8th gear, i find it quicker to mash the pedal in auto mode, it kicks down to a low gear and then i can flick over sports + vs trying to manual flicking down 5 gears or is there a better sequence of doing things.
Im reasonably certain its floored all the way. What makes me think it is, is that it downgear to a lower gear but in 2 stages. I figured if it wasnt floored all the way, it would downshift say from 8 to 5 but thats it whereas it can go from 8th to about 5 and then to 3 if i keep it depressed all the way.
Although i do the same thing minutes later and it will go all the way from 8 to 3rd gear etc.
So i take it your ISF doesnt do this? Next time ill definitely make sure i mash the pedal to be sure
Car is definitely warmed up, never push it when cold.
I remember reading on this forum that the transmission computer learns your driving habits. In my experience (in sport and automatic mode) if, after the car is warmed up, you drive around like an ******* for about 5-10 minutes the transmission will downshift quicker and skip more gears during the downshift when you press the accelerator, skip more gears and blip the throttle during quick deceleration, and keep the RPMs high while lightly accelerating (in other word it holds the gears longer because it's anticipating you mashing the throttle at any moment and needing torque).
I imagine it acts the same in normal mode. It will probably do a two stage downshift the first time you go full throttle, so 8-6-3 or whatever. But if you mash the throttle a few times in normal mode, I imagine the computer will "get the hint" and downshift more aggressively (like from 8-3 at full throttle).
In other words ISF5L, what you experienced is normal.
Check out this pdf
aa80e.pdf
Check out this pdf
aa80e.pdf
ISF5L (10-12-17)
There is a sensor under the throttle pedal and if you don't push the pedal hard enough it wont engage the lowest gear possible, have a look, there is a tread on here somewhere about pulling the spring out and making it softer cheers.
![Driving Skid](https://www.clublexus.com/forums/images/smilies/drivingskid.gif)
ISF5L (10-12-17)
I experience this as well, sometimes it’s 8-3 other times 8-5-3
I also find in 7th it’ll drop 7-4-2 at some speeds where as at some speeds it’s 7-2 instantly. On the motorway at 70mph it’ll drop from 8th right down to 3rd fast.
Maybe its speed dependant? Dunno, it’s a bit annoying sometimes.
Could it be fluid levels?
ISF5L (10-12-17)
My fluid levels are good as just got serviced few days ago.
What i was surprised about and never really paid attention but this morning, similar situation, i mashed the pedal hard and it went from 7 to 2 which is what i wanted however i saw the gear change to 2, the number 2 displayed on the dash but it was a good second or so (delay) before it acted like it was 2nd gear. i.e. It went instantly from 7 to 2, pedal still floored but nothing happened for a second or so and then it accelerated. Mind you only explanation i have that comes to mind was that it was normal not sports mode.
So this time, the transmission changed how i wanted it so the pedal did its thing, it just didnt accelerate instantly. Its like the engine had to catch up with the transmission or something like that. Maybe im being too picky lol
Have you had your car tuned if not get the RR tune, ^^^^ mine was the same small pause before kicking down, after tune very fast kick down ( I wish I had gone RR just for the 7200 redline and it is cheaper than OZ tune )
Saw few more Sydney tuners but they do lack the experience vs the tuners in the US like RR.
