LAG when mashing the gas
Just in case we over looked this, I'll repost the kick down switch. I haven't noticed any delay in downshifting if you depress the pedal fully; even if I'm cruising in 8th and need a quick highway pass.
Here's a photo and a link to the kick down thread.
https://www.clublexus.com/forums/is-...gas-pedal.html
But in sport mode off, regular drive, yeah its not that fast. But I expect that in normal setting
Its not being reset. It does in some cases change the learned curve. Its been fixing TBW vehicles for years and is easier than a battery discount and resetting all windows, audio....
Plenty of Yoda's snap back to life after doing this simple pedal press.
The 350 has 50,xxx plus mile since last ECM reset and no lag so I haven't had a need to do it. If it did lag I would try it.
I think it mainly helps those who never apply WOT in all gears.
Try it. Worst case is a loss of 30 seconds of your life.
Tech Info Resource
Tech Info Resource
Small update to this thread. I did some datalogging this evening in the GS F and looked at throttle position vs. accelerator position vs. kickdown switch status. It's interesting the computer says there's no difference in throttle position if you hit the kickdown switch or not.
The following 3 users liked this post by lobuxracer:
Tech Info Resource
Might be interesting to replicate this after the pedal dance. Also might be interesting to do the same with the IS F - mine still doesn't have the brake and throttle interlock software, so it's on the original engine management from '08.
