LAG when mashing the gas
is it normal for ISF’s to experience a slight delay when in the regular Drive mode?
in sport mode it’s a bit more responsive, but i never expected the throttle response and transmission to take that long to start doing work when merging on these freeways.
If you experience delay in throttle response as in the car hesitated to move, it is not normal.
Bigjon3475 (06-21-18)
Idk about lag but the of course in regular drive its a lot less responsive than in sport mode. Its hard for me to really even drive the car in normal cause I ususally always have it in sport mode cause I love the response. I wish the ISF was like the E92 where you could set the car in sport mode 100% of the time vs having to push the button every start up
I hate that too about the ISF, it's exactly the same as turbo lag...anoying!!! It's mostly because the tranny has 8 speed. The best is to drop at least 2 gear, to get really moving!!
APEXi sells a product the does exactly what your looking for ..
SMART Accel Controller Harness, 2014+ Lexus IS350
It’s called gear hunting. Something automatics do when demanding full power when you’re in an overdrive gear. I would say it’s almost a big negative with a car of this performance level. Drive any year BMW I don’t care what it is. You floor it and hit the” kick down switch”(button under the gas pedal) and it’s an immediate downshift into the lowest gear possible right away. I get the same response from my Audi as well. But merging or suddenly needing full power. The ISF has to think about it for 2-3 seconds before it decided to do something. I would say that’s where my previous C63 never had a problem, even in comfort mode.
Humor us and do a little experiment.
Ignition ON, engine OFF, swiftly press the gas pedal to the floor 3x and let it snap up.
Now, press the pedal to the floor smoothly and evenly taking about 8 sec to reach the floor pressing at a fixed consistent rate. Let off at the same rate. Repeat this twice.
Turn the ignition off.
Go test drive.
Also, when is the last time the battery was disconnected?
Go test drive.
Tech Info Resource
Go test drive.
Go test drive.
My Q7 is faster to downshift than the ISF.
Sometimes the ISF gets it right the first time and other times it just gear hunts more than it should.
