Alignment Specs Setup
There seems to be quite a few alignment related threads. I was in shock when I took off my front wheels to find the inner tread showing the steel belts! Anyway, I have had the USRS installed and am looking for optimal alignment specs for to be as nice to the tires as possible. I'm not planning to track this car. Let me know if you there are any custom recommendations or is the factory specs the way to go?
Thanks in advance.
Thanks in advance.
set your toe close to 0 and have the left and right settings match. how many miles on the tires and how many miles since you installed the USRS bushings? most alignment shops do half *** work so i hoefully someone can recommend something in your area. Do ask for a print out as well - better yet, tell them to print it only after they finished making their adjustments and tightening everything.
I’ll try to find my alignment spec sheet. The shop I went to here in Louisville KY specializes in alignments and working on high end cars. I’m not noticing any inner tire wear, yet,(it’s been about 5000 Miles)since my USRS bushings. They also completely eliminated my car pulling to one side. It’s gone.
Go go to a professional shop that specializes and not a chain store.
Legender
05-24-13 03:39 PM
