Phone Connection Failed - Bluetooth ISF 2008
I understand that the IS F doesn't have Bluetooth for 2008.
Although, I have been getting a notification on the screen saying that a phone failed to connect... I have no clue how to fix it, and I have no idea where I can access it on the navigation system.
Anyone else having this issue?
Questions aside -
Is there a way to integrate Bluetooth into the 2008 system?
Questions aside -
Look at Post #3 here:
https://www.clublexus.com/forums/is-...bluetooth.html
You do have BT for your phone.
Lou
Lou
OneFastF (12-29-17)
Lou
Lou
A fairly inexpensive BT receiver will enable you playing music through your smart phone. However, the control function is through the phone, no steering wheel accessible.
https://www.bestbuy.com/site/rocketf...?skuId=9976103
The other option is using a 3.5mm cable, assuming no XM installed.
It is all good just got an aux cable for 10 to keep things simple haha. Thanks for all the help you two.
END OF DISCUSSION
END OF DISCUSSION
Questions aside -
Questions aside -
should be two types of bluetooth connection areas one for audio and one for the phone calls.maybe this video might help
