Tire Pressure sensor standard?
Old 01-02-18 | 09:26 PM
FlexedLEX's Avatar
FlexedLEX
Default Tire Pressure sensor standard?
2010 Isf owner here...
I see the option to toggle to the tire pressure reading on the dash by using the switch to the left of the steering wheel...but nothing shows up for the pressure measurement. Do we have to install our own sensors to utilize this on the car?
I thought a car if this caliber would have something like this standard...
Thoughts/advice?
Old 01-02-18 | 10:25 PM
BlckGhst's Avatar
BlckGhst
AFAIK, there is no individual PSI measurements. Just a TPMS light
Old 01-02-18 | 11:27 PM
j3ff's Avatar
j3ff
Thoughts/advice?
The sensors are standard and youll find the 2IS actually holds two sets (8 sensors). There aren't many platforms that will let you do that.
Old 01-03-18 | 12:43 AM
FlexedLEX's Avatar
FlexedLEX
So can you see the psi measurements on the dash?
Old 01-03-18 | 05:12 AM
Joker4096's Avatar
Joker4096
No you cannot see the psi measurements on the dash. The only way to see the values is with techstream software and the obd2 cable.
Old 01-03-18 | 07:24 AM
NSXGuy's Avatar
NSXGuy
My wife's 2012 Toyota Highlander does
Old 01-03-18 | 08:46 AM
j3ff's Avatar
j3ff
Whaaat. My '17 highlander doesn't even! Neither does my dad's '13 rx450h.
Old 01-03-18 | 08:50 AM
NSXGuy's Avatar
NSXGuy
We do have the Hybrid Limited. Maybe that's why?
Old 01-03-18 | 09:15 AM
jdmSW20's Avatar
jdmSW20
Yeah there is no way to see the value on the dash like other make/models, we just have the tpms light that goes off
Old 01-03-18 | 09:29 AM
mikersoft's Avatar
mikersoft
And when it does, it's usually as you're leaving for work in the early morning on the first very cold day of fall/winter!!
jdmSW20 (01-03-18)
Old 01-03-18 | 12:08 PM
jdmSW20's Avatar
jdmSW20
Man....... story of my life
Old 01-03-18 | 12:31 PM
flowrider's Avatar
flowrider
^^^^When the light pops on, always seems to happen at the most inopportune time, you don't need to panic and rush to fill up with air. It's usually just a lb. or 2 under the sensor's reporting point. Sometimes, just driving on the FW will heat up the tires enough to turn off the light. Anyway, I usually wait until the next day, when the tires are cold from sitting overnight before checking and refilling all of them. Any yes, my Silverado reports the pressure by wheel, but not the ISF.
Lou
Old 01-03-18 | 02:37 PM
Bigjon3475's Avatar
Bigjon3475
“How to initialize the tire pressure warning system
To initialize the system, use the satellite switch. (P. 319)
Park the vehicle in safe place and turn the “ENGINE START STOP” switch to OFF.
While the vehicle is moving, initialization is not performed.
Adjust the tire inflation pressure to the specified cold tire inflation
pressure level. (P. 498)
Make sure to adjust the tire pressure to the specified cold tire inflation pressure level. The tire pressure warning system will operate based on this pressure level.
Turn the “ENGINE START STOP” switch to IGNITION ON mode.”
Page 387-388 of your 2010 Owner’s Manual.
http://drivers.lexus.com/t3Portal/do...f/OM53A21U.pdf
Noelma
CT 200h Model (2011-2017)
08-24-21 09:38 AM
rick3242
11-22-17 06:06 AM
Smoky350
11-18-06 04:01 PM
robinzon
GX - 1st Gen (2003-2009)
15
01-20-06 07:09 PM
robinzon
01-18-06 07:29 PM
