Stock ISF air filter
They usually cost between 50-60$. What change interval are most using? I know many have changed to Toms. How often is that cleaned and how long does it last?
I saw in one of the long oil threads(the Blackstone one?) that Danial recommend using a cheaper one and changing it more often as a more effective way of maintaining your engine.
Id like some opinions on what most of you are doing.
Thanks
Thanks
Greatest (01-18-18)
Greatest (01-19-18)
Looks like the Wix air filter is a 49150.
Try the look up at: http://www.wixfilters.com/Lookup/App...aspx?Section=1
Probably the best kept secret in filters for anything, is Baldwin filters. You don't hear a lot about them except where someone doesn't want to take a chance. Read that as marine applications and/or heavy duty trucks
Tech Info Resource
I use OEM filters. I don't recall recommending WIX based on personal experience. I know they make good stuff, but I haven't run their air filters in my cars.
I generally don't like aftermarket filters. Too many bad experiences (see my signature) with supposed performance enhancing junk that didn't.
Cabin air filters, sure no big deal. Engine air filters - you will very likely find an OEM filter in my cars. I don't trust a filter you can clean because all you can clean out of it are the big pieces. Oiled filters are crap for long engine service life, I don't care who makes them, and they have a tendency to foul MAF sensors if they are even slight over-oiled.
Besides, there are only two issues you can have with an air filter - it doesn't adequately protect the engine from small silicates, OR it gets clogged and reduces maximum power. The only reason for frequent engine air filter changes is to ensure you can always get maximum power from your engine at WOT. Otherwise, it's just another operating cost you can manage by deciding when performance is sufficiently degraded to warrant spending money on a new one. It won't impact fuel economy or driveability under 99% of normal use.
Totally agree on oiled filters. Had a bad experience on an Evo.
So how often are you changing it? 15k ? I can’t remember nor find the factory’s recommendation and what is your recommendation? Danial said in the Blackstone thread he recommended more frequent changes and said using a cheap filter more often would be better for the engine than going longer on the stock one.
